Hifi Coding
06-17-2016, 12:51 PM | #5 |
614
Rep 824
Drives: G80 M3CX (Oxide Grey)
The newer head units use an optical fibre connection (MOST) for the headunits so coding can only be done using an ICOM (and not the OBD port).
My 2011 LCI uses MOST, in the past I have coded a 2007 pre-LCI using just the OBD port. |
06-20-2016, 06:21 AM | #8 |
729
Rep 1,815
Most is the Fiber optic com that BMW uses between head unit, amp, changer and TCU or COM box.
To properly code a NON Most deck you need an ICOM head. To properly code a MOST deck (including CIC) you will need to use ICOM with MOST head. CIC can be coded with DCAN cable without issues. You can sometimes trick a MOST (non CIC) deck with a DCAN cable into taking coding.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
