06-14-2016, 05:15 PM | #1 |
33
Rep 77
B58 squeak - faulty tensioner/slipping belt
Sup everyone!
I got my B58 2 weeks ago... First off, what an amazing car. I didn't think they can make it any greater and they did. So now onto my problem. When I start my car I let it idle for about a minute or two. When I start driving, the first shift from first to second gear there's a squeak that occurs or you can hear the gear going into place like a tight shift on a MT. This only occurs on the first shift. Never happens afterwards. Also when in sports mode, the car shifts a lot rougher than usual as if the gears go in just on time. I have an 8 speed AT. Has anyone experienced something similar? I've got an appointment at bmw on Thursday.
Current:2021 X5 M50i | 2022 XB7
Old: 2013 335i x-drive |retired 05-2016 ||2014 320i x-drive | retired 03-2018 ||2016 340i x-drive |retired 03-2018 ||2018 X5 |retired 06-2021||2018 430i | retired 10-2021 Last edited by BeaminBimmer; 06-23-2016 at 10:28 PM.. Reason: More precisely describe the problem |
06-14-2016, 05:28 PM | #2 |
169
Rep 548
Drives: 2011 E90 M3 ZCP
So just to clarify, it only happens once per drive cycle? Can you reproduce it 100% of the time? I haven't had any issues like that with mine so far.
The quick/rougher shifts in Sports mode are definitely normal. |
06-14-2016, 05:44 PM | #3 |
33
Rep 77
I know how it shifts in sports mode. The past week doesn't feel normal. Kinda feels like it slipping and catching it back. It feels too harsh.
As for reproducing the squeaking noise it happens every time without fail but just from a cold start. If it doesn't squeak it sounds like grind, same noise as putting a manual car in reverse. |
06-14-2016, 05:49 PM | #4 |
169
Rep 548
I'd suggest putting your phone in the engine bay somewhere (not kidding) and taking an audio clip of it. Just for further evidence to the tech or shop foreman when you head into the dealership.
Good luck! |
06-14-2016, 06:47 PM | #5 |
33
Rep 77
It actually is a good idea. On my N55 I was hearing a noise that sounded like an exhaust leak. Went to bmw and they said everything seemed fine and they couldn't hear anything. A week later my check engine light came on and it was the O2 sensor and then they were like heyyy you had an exhaust leak. Which I told them that's what I thought it was the first time.
06-14-2016, 09:53 PM | #6 |
284
Rep 360
I have a 340 as well , no squeak but I do warm up my car for about 5 min before moving it. Try that see if it helps
2016 340I build thread : http://f30.bimmerpost.com/forums/sho....php?t=1266037
06-15-2016, 03:14 AM | #7 |
2JZ-GTE
3005
Rep 3,986
I have a 340 and when the car was new the transmission was very tight. I found after a thousand or so miles it loosened up.
06-15-2016, 11:06 AM | #10 |
169
Rep 548
Wow, that's definitely interesting. Glad you were able to capture it!
Looking forward to see how the dealership handles this. |
06-15-2016, 11:13 AM | #11 |
33
Rep 77
I sent the clip to my sales rep he said he thinks that it's the turbo flap... Which I strongly doubt. It does it exactly when shifting between first and second gear and in this clip it did it from 2nd to 3rd. It didn't do it afterwards.
06-15-2016, 07:32 PM | #12 |
105
Rep 146
Drives: BMW's
Garage List 2020 G07 X7 [0.00]
2013 E70 X5 [0.00] 2003 E46 M3 [0.00] 2013 F10 M5 [0.00] 2009 E90 335ix [0.00] 2009 E90 M3 [0.00] |
I hear the same noise from time to time. Being a BMW tech and never hearing anything like it I assumed it was possibly the serpentine belt slipping a bit from the abrupt change in engine rpm (since the 1st to 2nd change is hardest) but i could be completely wrong there. It is quite an irritating noise though.
06-16-2016, 02:22 PM | #13 |
Rep 12
Funny, I thought I would be the only one complaining when I bring the car in for service.
I get exactly the same issue, but when I am under heavy throttle and shift super early like 3000-4000 RPM. My initial thought was a belt slip since it only seems to happen when the engine is cold. |
06-16-2016, 02:35 PM | #14 |
33
Rep 77
Brought my car this morning. It didn't make the noise!! They kept all day and tried a few times and it didn't do it.
I'm going tomorrow AM to test drive it myself with a mechanic. I told them that it might be the serpentine belt (someone here in Montreal also said the same thing). But they didn't bother taking a look. |
06-16-2016, 02:39 PM | #15 |
24
Rep 38
06-17-2016, 07:29 AM | #17 | |
191
Rep 603
- 2022 X3M Comp
- 2021 X5 xDrive 40i - 2018 F80 M3 (sold) |
06-18-2016, 10:42 AM | #19 |
309
Rep 1,733
Drives: 2003 M3
I have this noise too. It's like a fan belt/power steering pump type noise. I don't think it's transmission related. But it is at the shift point which is interesting. Sounds to me like it comes from the engine bay, driver's side.
I'm not bothering with going to the dealer because same thing is going to happen. Won't make the noise when it's there. You would have to leave it over night and have them run it first thing in the morning. It will be my N54 turbo rattle saga all over again... |
Aldor2787.00 |
06-18-2016, 05:06 PM | #21 |
33
Rep 77
Here's an update on my situation. The dealer I went to on Thursday did nothing with my car since they couldn't hear the noise themselves. They said the video wasn't enough. I went to another dealer on Friday, he asked me to see if I can reproduce the noise with the a/c on or off. I've been testing the car with a/c on and off and so far only happens with the a/c ON. Sound is coming from the engine bay on the driver side.
06-20-2016, 06:01 PM | #22 |
33
Rep 77
Got an appointment on Wednesday at 8 AM. The deanship believes they've narrowed it down to a belt that has to do with A/C. Will keep you posted
Old: 2013 335i x-drive |retired 05-2016 ||2014 320i x-drive | retired 03-2018 ||2016 340i x-drive |retired 03-2018 ||2018 X5 |retired 06-2021||2018 430i | retired 10-2021 |
