Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > 32E3 DME fault?
      06-14-2016, 04:05 AM   #1
Dhillon92
82
Drives: '11 335xi
32E3 DME fault?
Hey guys, recently after my comfort access and amp stopped working, I have received this code: 32E3 EWS-DME Interface Hardware fault.
Any ideas on what can be done to fix this? The only thing I have done coding wise is install the PPK to my N55.
Thanks
///FBO+METH 6MT N55///
      06-14-2016, 11:24 AM   #2
Sensible_
529
Drives: 2008 E90
Thanks
Seems to hint at a hardware fault between CAS / DME. Check all wiring between them. Make sure there's no water ingress...
      06-14-2016, 07:19 PM   #3
Dhillon92
82
Drives: '11 335xi
Where exactly is the CAS module located? I'm not very electrical savvy but I will try and look for any obvious signs.
      06-15-2016, 01:29 AM   #4
Levanime
BimECU
Levanime's Avatar
193
Drives: BMW
2007 BMW 335  [0.00]
you will need WDS,
you will find all info in it, CAS location and wiring/pins as well
      06-15-2016, 05:00 AM   #5
Dhillon92
82
Drives: '11 335xi
Originally Posted by Levanime View Post
you will need WDS,
Thanks, I will look into that. I once had smoke coming from under the drivers door sill, immediately after my car stopped recognising my key and I had to insert it for it to start.
So that answers why my comfort access has stopped functioning, is the radio amp also controlled by the CAS? I have an individual sound package, would be good to know if I'll be fixing both problems at the same time.
Car is still under CPO, but demodding the downpipe and meth would be a pain in the ass so I will see if I can fix it myself.
Thanks for the guidance, I will report back with my findings.
      06-15-2016, 09:19 AM   #6
hassmaschine
3973
Drives: "NBO" 330i
does the car still run? does it say the error is present/not present?
if the CAS weren't talking to the DME at all, it should not start. Otherwise, it could be an intermittent failure. IMO, the CAS system is complicated enough and you are CPO, it would be best to just take it in and let them fix it.
      06-15-2016, 03:04 PM   #7
Dhillon92
82
Drives: '11 335xi
It does still run, the car performs as expected, its just some if the electrical components that are problematic. The code seems to be constantly present, I clear it and read again and it still shows.
I guess if its that complicated I will leave it until the winter and take it in then, I'd rather not pull all my mods and deal with dealership turnaround time during the good weather.
Thanks
      06-17-2020, 02:39 PM   #8
ghost135i
ghost135i's Avatar
52
Drives: 2012 135i DCT
Were you able to figure out the issue here?
      06-03-2023, 05:02 PM   #9
Nitolin79
Drives: 2012 BMW X5 35i
Please any findings on this error ?
      03-25-2024, 06:10 AM   #10
Mido01
Drives: 2012 BMW X1 xDrive28i
Did you figure it out?
      03-27-2024, 02:23 PM   #11
Dhillon92
82
Drives: '11 335xi
I get this code till this day lol, ive written it off as probably from my comfort access doorhandles not working and then me disconnecting them.
