BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > [E91] 320d flashing alpina D3 software
      06-10-2016, 06:57 PM   #1
Nobless
Nobless's Avatar
Lithuania
Drives: E91 320D 120kw
Red face [E91] 320d flashing alpina D3 software
Hello, i have E91 2006.06 320D Automatic transmission and i tryed to flash Alpina D3 using this thread info http://www.e90post.com/forums/showthread.php?t=709020, used D+KCAN cable with WinKFP, by these steps:
"in WINKFPt this software is marked as 7811921 under DDE604. You go to Comfort mode, click on Choose ZUSB and find 7811921 somewhere in DDE604 .. Then OK, enter VIN and DONE. Then click on Program and it should start flash. I used classic OBD K-Line cable and I haven't used any battery charger since the flash is not longer than 15 minutes." flashing was ok, and after flash i got transmission error, dsc error and so on...
also tryed: "after doing this coding the car will be Dead and show a gear warning on cluster but this can be fixed by correctly updating the NCSexpert...
Here is what you do:
0-Start ignition with cluster lights on
1-Load NCSexpert
2-File Use EXPERTMODE profile and click ok
3-(F1) Vin/ZCS/FA
4-(F3) SG ausw
5-Choose E89 chassis click ok
6-Choose CAS click ok
7-(F6) Back
8-(F4) Read ECU and pick EGS module click ok
9-Press F3 (execute JOB)
10-After it says coding ended your done!
11-Close out NCSexpert
Coded was fine also, but nothing changed, still transmission error and it says that it is defective, also i cant start my car anymore.. also tryed to clean errors with INPA same problem.
The tools i used http://www.e90post.com/forums/showthread.php?t=1220039..
Don't know what to do... how to flash stock back again...
      06-10-2016, 07:16 PM   #2
Nobless
Nobless's Avatar
Lithuania
Is this cas module could be a problem ?
Code:
   E R R O R   M E M O R Y           -----------------------
Date:      11.06.2016 00:19:13
Model:     E89X
Scope: all control modules.
JobStatus: OKAY Quantity:  21
	ADR Gen. name  JobStatus Number of errors              Error code   Kind of error 00  JBBF       OKAY      1 Error stored                C915         64
 	01  MRS        OKAY      No Error stored
 	17  EKP        OKAY      1 Error stored                CED4         28
 	18  EGS        OKAY      5 Error stored                CF17         64                CF16         64                CF15         64                CF14         64                CF21         34
 	36  TEL        OKAY      No Error stored
 	3C  CDC        OKAY      No Error stored
 	3F  ASK        OKAY      No Error stored
 	40  CAS        OKAY      3 Error stored                A0B3         28                A0B1         28                A110         28
 	41  DWA        OKAY      No Error stored
 	44  SHD/MDS    OKAY      No Error stored
 	47  ANTTU      OKAY      No Error stored
 	50  SINE       OKAY      No Error stored
 	56  FZD        OKAY      1 Error stored                A670         28
 	60  KOMBI      OKAY      4 Error stored                A3B2         20                A3AD         60                A3AE         60                A3AF         60
 	62  MOSTGW     OKAY      No Error stored
 	63  MASK/CCC   OKAY      No Error stored
 	67  ZBE        OKAY      No Error stored
 	72  FRM        OKAY      No Error stored
 	73  CID        OKAY      1 Error stored                A468         64
 	78  KLIMA      OKAY      5 Error stored                E717         64                E71A         64                E71B         64                9C53         68                E720         64
 	A0  CCC        OKAY      No Error stored
i can clear errors, but after i trying to start a car same error list.
      06-10-2016, 09:30 PM   #3
Levanime
BimECU
Levanime's Avatar
193
Drives: BMW
2007 BMW 335  [0.00]
Did you try to flash your EGS back to stock?
looks like your DDE is not communicating anymore,
try flashing stock back, if it doesnot work you will need to try NFS
      06-11-2016, 02:57 AM   #4
Sensible_
529
Drives: 2008 E90
I think your battery is low. Charge it then try to re align CAS / DDE.
Just flash DDE back to stock and also update EGS.
      06-11-2016, 07:50 AM   #5
Nobless
Nobless's Avatar
Lithuania
which ZB number should i flash to go back ? 7811921 is Alpina, but which is mine ? there so many ZB numbers, which will be correct with SPDATEN v55
      06-11-2016, 12:10 PM   #6
Nobless
Nobless's Avatar
Lithuania
just updated in comfort mode CAS, then DDE, and EGS, now no errors in dashlight but car still doesnt start.. also DDE comeback in the list but still something wrong have some errors in inpa, and i could not delete few of them
      06-11-2016, 01:32 PM   #7
Nobless
Nobless's Avatar
Lithuania
Fixed, modules wasn't synced, used this guide
"Symptom is that everything works, engine cranks fine -- but no start (and no SES light). Fire up INPA and you'll see various codes, but the one that's the problem is '4A63 EWS Manipulation'. Means that two modules aren't synched, so the car believes there is a security problem and immobilizes the car.
The fix is easy (with INPA). E60>>Engine>>N52 [in my case]>>Shft F6 EWS -- Start value comparison and Shft F7 EWS CAS -- Start value comparison. In my case, EWS CAS resynched the modules and the car started right up.
Synced EWS module and now everything is okey, car starts up....
      06-11-2016, 03:49 PM   #8
Sensible_
529
Drives: 2008 E90
      06-11-2016, 05:42 PM   #9
Levanime
BimECU
Levanime's Avatar
193
Drives: BMW
2007 BMW 335  [0.00]
Nice!
pretty strange your CAS has no VIN and still works
anyways good it works now
