abs-dcs dynamic stability control premium
06-09-2016, 04:47 PM | #1 |
213
Rep 1,781
So I bought the schwaben programmer from ecs tuning and came across this option "abs-dcs dynamic stability control premium" the one before it was "abs-dcs dynamic stability control plus" then normal then Bosch then some other one. Each one could be activated and I'm assuming the other one would be deactivated.
When activated a pump would buzz for a few seconds which I assume would be the master cylinder. Is this an option to enable the e-diff? I left the premium version on.
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
