06-07-2016, 03:18 PM | #1 |
A family of bimmers
2748
Rep 7,742
Coding Alarm Beep Louder
I find the stock volume of the chirp of the alarm too soft. Is there anyway to code it louder? If so, could you please post what values should be changed?
Thanks in advance.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
06-07-2016, 09:24 PM | #2 | |
56
Rep 171
Drives: X3 M Comp
-NVE |
06-08-2016, 09:53 AM | #5 |
A family of bimmers
2748
Rep 7,742
I found this just wanted to have someone confirm its right before I try it. Can't imagine it being much different from the other models. This was from an x5 forum.
FZD Buzzer high set to 01 FZD Buzzer duration set to 04
06-08-2016, 02:00 PM | #6 |
Rep 13
From another post:
F20 FZD 3001 LIN_SINE Buzzer level high initwert,level_3 level_10(MAX) F20 FZD 3001 LIN_SINE Buzzer frequency werte=8F Min 7D~ Max AF F20 FZD 3001 LIN_SINE Buzzer duration werte=0A Min 01~ Max FF |
06-08-2016, 04:03 PM | #7 |
A family of bimmers
2748
Rep 7,742
Sounds like i just need to set the buzzer level high init to something greater as its probably on 1 now. going to give this a shot.
06-23-2016, 08:44 AM | #9 |
A family of bimmers
2748
Rep 7,742
I have not gotten around to doing another round of coding. Will update when i do though.
07-13-2016, 01:12 PM | #13 |
13
Rep 143
I tested to code the following:
FZD 3001 LIN_SINE Buzzer level high initwert,level_3 level_10 FZD 3001 LIN_SINE Buzzer frequency werte=8F AF But it didn't change the volume on my car. I also tried to change the code: FZD 3001 LIN_SINE Alarm type Mine is default ECE, tried both US and GB, but the sound is the same. Sniper101 Can you check what your car has as default? |
