Oil Quantity / Level?
06-06-2016, 03:58 AM | #1 |
Rep 193
Morning,
car has recently been serviced and the garage left me the remaining oil in the boot from the 2 x 4l containers. the oil level sensor was showing ok but just above the low level mark, so I topped up with oil. it has had nearly 7l and it hasn't budged up the scale? any ideas? thanks |
06-06-2016, 01:07 PM | #3 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Give it a while to settle down after the change. You may well find it will rise to full.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-07-2016, 06:50 AM | #4 |
18
Rep 189
You are following the correct method I take it? From the owners' manual:
"For a precise measurement and display of the oil level, it is necessary that the engine be at operating temperature, i.e. after uninterrupted driving for at least approx. 6.2 miles/10 km. You can have the oil level displayed while you are driving, or while the vehicle is at a standstill on a level surface and the engine is running." |
06-08-2016, 05:57 AM | #5 |
283
Rep 2,343
The car's readout is pretty crap.
If you want to really know how much oil is in it then use INPA or an app like Carly. Then you can add as much as you need. The idrive and BC readout can vary alot up and down depending on the angle the car is at when it's measured. It'll only tell you about the top 1 litre as well. In the past if mine was half way down after measuring on a flat surface I'd add some and then let it remeasure. It's a shame they ditched the dipstick. This stupid electronic measurement causes all kinds of questions and confusion.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
