Netodat coding night time gauge light voltage (I need help)
06-05-2016, 11:49 AM | #1 |
Bob Saget
355
Rep 2,229
Gents, my coder and I are trying to find WHERE to go to change the voltage for the gauges.
At night, when gauges are lit, I am given 10 "steps" to change the brightness. 1 being very dim. 10 being very bright. The only thing we have seen with "ten" steps in it I have attached. But we don't think this is it. I tried asking on the german forums and got no where. What I am looking to have is the following: -Off completely when I am extreme rural areas so I can have max visibility out the car -Second "step" would be very dim like factory dimmest setting -Third and final step would be max brightness (when I'm in the city and want to show off my mood lighting, on a date, etc...) The ten factory "steps" are just a lot that I don't need. Plus none of them turn off my gauge lighting which I was use to being able to do and LOVED on my 350z and also my Lexus IS-F. Having the gauges off, when I knew how fast I was already going was very very nice for outward visibility and gave me the ability to feel safer by having no light distraction inside the cabin.
In memory of Robert E. Flynn (AR)
06-05-2016, 11:51 AM | #2 |
Bob Saget
355
Rep 2,229
Again as you see attached, these were the only items that we could find in the KOMBI that had 10 wert values.
Yet the german translation says nothing about gauges.
06-05-2016, 06:57 PM | #6 |
529
Rep 2,503
I think you should look to FRM...
Code:
U_POTI_DIMM_MIN 00340203 (01) FF INSTRUMENT LIGHTS DIMMER POTENTIOMETER MINIMUM VOLTAGE [VOLTAGE_V=(DATA*5)/255] wert_01 38 38 value 01 PL2 U_POTI_DIMM_DELTA 00340204 (01) FF INSTRUMENT LIGHTS DIMMER POTENTIOMETER VOLTAGE SPAN BETWEEN MINIMUM AND MAXIMUM [VOLTAGE_V=(DATA*5)/255] wert_01 99 99 value 01 PL2 MELDUNG_AENDERUNG_DIMMER 00340205 (01) FF INSTRUMENT LIGHTS DIMMER CHANGE BEFORE K-BUS MESSAGE GENERATED [ANGLE_°=(DATA*120)/255] wert_01 07 07 value 01 PL2 TASTVERH_KL_58G_MIN 00340206 (01) FF MINIMUM BRIGHTNESS PULSE DUTY FACTOR FOR INSTRUMENT LIGHTS (BASE WIDTH) wert_01 11 11 value 01 PL2 ZUWACHS_TASTVERH_KL_58G 00340207 (01) FF MAXIMUM BRIGHTNESS PULSE DUTY FACTOR FOR INSTRUMENT LIGHTS (ADDED TO BASE WIDTH) wert_01 EE EE value 01 PL2 wert_02 42 42 value 02 POTI_DIMM_INVERS 00340208 (01) 01 INVERTED POTENTIOMETER INSTRUMENT FOR LIGHTS DIMMER nicht_aktiv 00 00 not enabled !(MAERZ07,NFRM_CI_31) aktiv 01 01 enabled MAERZ07,NFRM_CI_31 POTI_LWR_INVERS 00340208 (01) 02 INVERTED POTENTIOMETER FOR VERTICAL HEADLIGHT AIM CONTROL (LWR) nicht_aktiv 00 00 not enabled PL2 aktiv 01 02 enabled LEUCHTDICHTE_EXPO 00340208 (01) 04 EXPONENTIAL LUMINANCE CHANGE FOR INSTRUMENT LIGHTS nicht_aktiv 00 00 not enabled PL2 aktiv 01 04 enabled |
