Which Cable Do I need?
06-05-2016, 09:16 AM | #1 |
51
Rep 273
Can anyone recommend me a good (reasonably priced) cable to code my 08 E93?
I've seen a ton, but not sure because many people say its a hit or miss if you buy a cheap one. Thanks in advance |
06-05-2016, 10:13 AM | #2 |
167
Rep 1,415
http://www.one-stop-electronics.com/...&product_id=16
Or you can buy 5 20$ ones off ebay hoping one of them works then return the rest |
06-06-2016, 09:15 AM | #3 | |
522
Rep 1,527
06-06-2016, 02:59 PM | #4 |
298
Rep 410
Would this unit theoretically work for coding?
http://www.bafxpro.com/obdreader/ It works just fine as an OBDII scanner for my BMW, but it's a little obscure to me if it has the appropriate protocols for coding via NCS Expert. I'm having trouble getting connection with NCS Expert and am trying to figure out if I should just buy the recommended cable or if this SHOULD work and I need to put in some effort on the software/COM setup I guess I can copy paste the relevant part here: "Supports ALL OBD2 Protocols": SAE J1850 PWM(41.6Kbaud) SAE J1850 VPW(10.4Kbaud) ISO9141-2(5 baud init,10.4Kbaud) ISO14230-4 KWP(5 baud init,10.4 Kbaud) ISO14230-4 KWP(fast init,10.4 Kbaud) ISO15765-4 CAN(11bit ID,500 Kbaud) ISO15765-4 CAN(29bit ID,500 Kbaud) ISO15765-4 CAN(11bit ID,250 Kbaud) ISO15765-4 CAN(29bit ID,250 Kbaud) SAE J1939 CAN(29bit ID,250*Kbaud) CAN(11*bit ID,125*Kbaud) |
