06-03-2016, 09:30 PM | #1 |
BimmerPost Supporting Vendor
1991
Rep 6,916
BMW M Performance Coilovers and Rogue Engineering Suspension Parts
Some updates - Front Tension Arm Bushings and Sway bar links were replaced - suspension should handle a bit sharper with these mods, along side with the drop.
Car sitting pretty at Rogue Engineering 1M Race ready sitting next to the M2 Rogue Engineering Monoball Front Tension Arm Bushing Rogue Engineering Adjustable Swaybar Links Rogue Stainless Steel Brake Lines - custom made M Performance Coilovers One quick shot with of the suspension more coming. s Teasers courtesy of Ben at Rogue .... what a tease. Just one shot of the suspension. Check out the complete build here |
06-07-2016, 09:10 PM | #4 |
1991
Rep 6,916
got some updated photos from Rogue Engineering prior to the car getting an alignment.
Nice clean install co's are in, ss brake lines are in, adjustable sway bar links. car dropped wheels looking nice and on point. |
BAN_M2C4180.00 |
07-23-2016, 02:37 PM | #8 | |
146
Rep 371
The only ugly thing is the useless amber front bumper reflector. But thanks to iND there is a solution, at least when you live in the USA, outside USA the shipping cost are ruining the deal. Imagine you nice car without the ugly things ! Last edited by parrnan; 07-23-2016 at 02:50 PM.. |
07-23-2016, 10:02 PM | #9 | |
1991
Rep 6,916
08-03-2016, 10:40 AM | #10 |
1008
Rep 1,563
Hi,
Can you please comment on the Rogue tension arm bushings? On my old car, replacing the stock bushings (which are incredibly soft) with poly bushings made the car feel so much more alive. I am considering doing this to my M2 but am unsure if I want to go with monoball bushings or their press in aluminum/urethane ones. What is NVH like with monoball bushings, and what is the expected lifespan of the monoball ones vs. the press in bushings? Your m2 looks phenomenal. I had a deal to get those same BBS wheels before the seller backed out on me. |
08-03-2016, 01:29 PM | #11 |
1991
Rep 6,916
it's much tigher I love them. where are you located...if you are around you can check out the cars back to back.
lmk maybe I can work a deal with you on the bbs I have a set available for sale brand new in the box. |
10-24-2016, 09:04 PM | #13 |
Avid Car Enthusiast
152
Rep 266
beautiful! can you please PM me a price also?
History will never be forgotten
1992 Red Acura Legend 4dr, 2003 Daytona Blue Nissan, 350z 6spd, 2007 Black Audi B7 RS4 6spd Current Girlfriends Alpine White BMW M2 6spd; 2015 Arctic White Yukon XL Denali |
10-24-2016, 10:00 PM | #14 | |
3816
Rep 54,319
Drives: F80 M3
http://www.hpashop.com/Rogue-Enginee...e-monoball.htm http://www.hpashop.com/Rogue-Enginee...t-F8x-M3-4.htm |
jetbill198.00 |
10-26-2016, 07:55 AM | #15 |
1991
Rep 6,916
10-26-2016, 11:39 AM | #16 | |
267
Rep 347
I have these also mounted and have the recommended height from BMW (595 mm and 600 mm). On front I can drop additional 10 mm but on rear i have reached max. To conclude: original vs Mperformance in lowering with standard recommended height; Front: 25 mm (1") possible to go to 35 mm Rear: 15-20 mm Cheers |
10-26-2016, 11:41 AM | #17 | ||
267
Rep 347
Front was after the picture additionally lowered. |
05-22-2019, 02:42 AM | #19 | |
1774
Rep 4,511
Did you fit adjustable sway bar links at the back as well or stay with OEM rear sway bar links ? BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
06-01-2019, 08:04 PM | #20 |
33
Rep 28
06-02-2019, 02:55 AM | #21 |
844
Rep 1,962
06-02-2019, 03:06 AM | #22 |
844
Rep 1,962
The spring rates are higher, so this you notice. But, given that they are valved so that rumble strips (and lane markers, manhole covers and potholes...) are absorbed the same regardless of setting, it's more a case of how you want the car to feel.
if you use the track settings, there will be little to no weight transfer at license friendly speeds on the road, leading to a pretty anodyne driving experience in bends. How much softer you go depends on where and how you normally drive. I'm currently running 2 clicks softer all round than the recommended road settings as it makes it much easier to get the car moving around in bends on the relatively tight and twisty rural routes I try to take. Jetbill's shock dyno thread suggests that this setting is still stiffer than the stock dampers though... |
Tags |
bmw m2, detailersdomain, rogue engineering |
