06-03-2016, 02:48 PM | #1 |
Rep 38
DCT Clutch Malfunction
When manually downshifting at highway speeds (>60 mph) the F10 rev matches and engine braking begins and then inexplicably the clutches disengage. The net result is that the F10 coasts and the revs stay elevated. Application of throttle is required to re-engage clutches. This phenomena will also occur occasionally while cruising at higher rpms. BMW of Manhattan has finally conceded that the F10 hasn't been fixed and will enter the problem in PUMA.
Has any one else experienced this particular DCT clutch problem? TIA
2014 F10 M5 Individual, Azurite Black, Competition Package, 20" 601 M Wheels, Ai Custom Laser Interceptor & BelSTiR Radar Package, Bang & Olufsen Stereo, Heads Up Display, Executive Package, Driver's Assistance Package, LED Lighting Package, DINANTRONICS Stage 2, Dinan Cold Air intake, Akrapovic Exhaust. Dyno'd 622RWHP.
06-10-2016, 01:00 PM | #3 |
2856
Rep 7,883
Either a software issue or your clutches are going bad. Easy way to tell if your clutches are going bad is to have your technician get a sample of the DCT hydraulic fluid and then send it off to Blackstone. Within a few weeks, you will have a detailed analysis of how your DCT is holding up.
07-24-2016, 02:12 PM | #4 |
430
Rep 1,108
I doubt you are having the same issue I had, but I had similar symptoms which was caused by not having the right size tires, Rolling diameter was off and it messed with the cars electronics, only happened at 60+ mph. Make sure you are running the correct size tires.
07-26-2016, 08:46 AM | #5 | |
317
Rep 843
07-26-2016, 09:52 AM | #6 | ||
430
Rep 1,108
combatbmw205.50 |
07-31-2016, 12:24 PM | #7 |
206
Rep 1,250
Drives: 20' X3M CP
Crazy how something so simple can do that.. damn
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
07-31-2016, 01:16 PM | #8 | |
430
Rep 1,108
10-11-2018, 12:36 PM | #9 |
Rep 7
hi guys! I have seen some M5 f10 (m6 also) that when your in full sport mode, MDM and all that. The Revs can Bounce, for exampel, if you have your revs at 3k, and you push the peddle full and let of the gas at the same seconds it sometimes Bounce a Little bit.
have you Heard or seen this fenomen? I have not seen this on my car yet, but my car is now sleeping for the Winter. I noticed some on the Youtube. i hope you can understand this strange fenomen, if you don't I will try to explain better. |
