Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Car won't start most of the times.
      05-19-2016, 05:10 AM   #1
G20 WestMid
51
Drives: White F30 M Sport
Hi there I have searched for the problem online before posting.
Basically the problem I'm having is that my 2010 320d won't start some times and soon as i use booster pack at the front of the car will start and will work fine for a few days.
I have just got the alternator and battery replaced. Still the same problem. Starter motor is fine got it checked.
I also read that if you disconnect the ibs lead the car will start. Which I did on sunday and the car was working fine until this morning had to use a booster again.
Would anyone know what the problem is or how I can fix it.
Thanks
      05-19-2016, 08:41 AM   #2
AWSAWS
AWSAWS's Avatar
283
Drives: E92 GC Turbos, FBO, 335i DCT
You should do a scan with diagnostic tools. DISv57 or better yet Rheingold. Check for example if you've got something that could be shorting out or not shutting down draining your battery. Do you see the low battery warning? Any codes thrown?
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos)
11.74@129mph (GC Turbos)
      05-19-2016, 12:10 PM   #3
G20 WestMid
51
Thanks for the info mate.
It was bad earth sorted now.
Did have a error for battery short circuit before.
