Timing Issue
05-18-2016, 12:24 PM | #1 |
Rep 3
Timing Issue
I recently purchased a 2011 328i xDrive with ~46,000 miles. It's been an incredible car so far but I have had an occasional timing issue. Often when I accelerate heavily, especially when kickdown is initiated, the SES light comes on and the engine rumbles and sounds like it is misfiring and running a couple cylinders down. I stop immediately, turn my car off and restart it and the engine is running normal again. I have done some research and it seems to be a spark plug/ coil issue. Are there any other possible causes for this problem and if it is a spark plug/ coil problem, around how much will it cost to fix. Thank you
05-18-2016, 01:51 PM | #2 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
Get someone to read you car's ECU for stored fault codes. That will take the guesswork out of what the real issues are...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Tags |
coils, e90, timing, vibration |
