2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) LED shop lights are the shit...
      05-15-2016, 03:17 PM   #1
BEM-S4
BEM-S4's Avatar
4515
Drives: Dinan M235, Dinan Sport Wagon
Picked up a pair from Home Depot, $40 each and you can string up to 9 of them together. Just hang from ceiling and plug into garage door opener outlet. I also got the GE wireless outlet switch to plug lights into them mounted switch on wall so you don't need to use the pull chain, that was an additional $20. Anyway I'm posting here because it made waxing the car and doing the interior MUCH easier since the light is so much better. Going to add a couple more. Will put some wire mold on the power cord once I've got the rest installed.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
Appreciate 2
      05-15-2016, 04:10 PM   #2
Tpeterson
Tpeterson's Avatar
157
Drives: 228i MSport/THP/MT/
Looks like a great idea.Been meaning to do something like that for years. What they about 8 feet or so long?
      05-15-2016, 05:01 PM   #3
BEM-S4
BEM-S4's Avatar
4515
No that's two hooked together. They are 4' each come w a 14" connector cord or a little stubby one to connect together like I did. Will use the cord for corners.
2022 Macan S
      05-15-2016, 05:52 PM   #4
Tpeterson
Tpeterson's Avatar
157
Thanks!
      05-15-2016, 07:08 PM   #5
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
one of the cleanest garages i have ever seen.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      05-15-2016, 07:11 PM   #6
eclipes
47
Drives: 228i Msport
Do you have specs on the lights
      05-15-2016, 08:35 PM   #7
BEM-S4
BEM-S4's Avatar
4515
Will post a link tomorrow. Just to give you an idea of the improvement with the door up at night you can see difference between old lights vs new pretty easily.
2022 Macan S
      05-16-2016, 07:52 AM   #8
BEM-S4
BEM-S4's Avatar
4515
Here are the lights I used. I found mounting directly to the ceiling via the keyhole screw option to be VERY difficult. I decided to just shorten the chain to 6 links instead, much easier.
http://www.homedepot.com/p/Commercia...3161/205331022
The switch I used is this one, but anything similar should work.
http://www.amazon.com/GE-18313-Outle...ilpage_o01_s01
      05-24-2016, 11:58 AM   #9
Spydeputy
Spydeputy's Avatar
Germany
205
Drives: 2015 F23 M235i/2008,E90,335xi
Jus the lights and their tombstones?
Hi BEM S4,
Did you think about using your old fixture, and just replacing the LED lights, and their tombstone?
Thanks for responding.
http://www.amazon.com/Hyperikon-equi...hts+for+garage
      05-24-2016, 03:33 PM   #10
BEM-S4
BEM-S4's Avatar
4515
Originally Posted by Spydeputy View Post
Hi BEM S4,
Not sure I follow. The only lights I had in there to begin with were 1 recessed light by the back door and the bulb in the garage door opener. It was really not adequate.
To answer where I think you are going with your question, I have no idea if what you linked would be better or worse if you have existing fixtures as opposed to getting all new lights. Wasn't an option for me so didn't investigate it at all.
      05-24-2016, 10:34 PM   #11
BentZero
BentZero's Avatar
624
Drives: 6MT Mineral White M235i
Hi BEM S4,
This is the route I'll probably go. I have 5 dual bulb fluorescent fixtures in my garage and it's still not enough light. This seems like a simple enough conversion.
I rev-match from neutral to first
6MT Mineral White on black M235i coupe
Build thread
      05-25-2016, 07:42 AM   #12
Spydeputy
Spydeputy's Avatar
Germany
205
My Bad, Sorry,
I was assuming that you already had shop lights (florsent type) and were up grading.
The link from amozon shows them, but I found Philips LED at Home Depot for $10.
http://www.homedepot.com/p/Philips-4...6608/206278132
      05-25-2016, 11:44 AM   #13
BentZero
BentZero's Avatar
624
My Bad, Sorry,
Oh nice. i may give a couple of these a shot.
Build thread
      05-25-2016, 12:09 PM   #14
Spydeputy
Spydeputy's Avatar
Germany
205
$10
For $10 bucks a tube you can't go wrong
      05-26-2016, 08:40 PM   #15
Supernaut
Little Deuce Coupe
Supernaut's Avatar
391
Drives: SO M2C
Thanks for the tip. I picked up one and really like it. I'll be adding another. I just had a single ceiling socket in the garage.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD
2020 Sunset Orange M2C|6MT|Black 788s
      05-27-2016, 09:56 AM   #16
Spydeputy
Spydeputy's Avatar
Germany
205
Did you get the Philips LED at the Depot?
      05-27-2016, 10:12 AM   #17
BentZero
BentZero's Avatar
624
how much brighter were the bulbs? i have 5 dual bulb fixtures. thinking of upgrading two of them.
Build thread
      05-27-2016, 05:21 PM   #18
Y0tsuya
77
Drives: 2015 M235i 6MT, 2016 340i 8AT
I went the DIY route and bought 12V LED strips off eBay, 5 meter 5050 60W for $10. I ripped some 2x4's into thin strips then stuck the rolls onto the strips. Each 5m roll will make 2x 8ft light strips. Then I bought a 12V 40A power supply for $50 and wired 14 of these light strips evenly through my garage ceiling. I now have 420W of super-bright and even LED lighting for less than $150 (have to buy wires and shit).
      05-28-2016, 09:26 AM   #19
NEUE02
NEUE02's Avatar
267
Drives: M235i
Good question. And what is the color balance like?
I have 15 quantity of 4' T8 fixtures in my garage. I would consider upgrading to LED if the color balance is similar. Going to be pricey, though, even at $10/bulb.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S
      05-28-2016, 10:20 AM   #20
orangeglim
345
Drives: 2019 M2C
2019 M2C  [0.00]
Just put three of the same lights as OP in my garage yesterday. They're much better than the two 60w compact fluorescent bulbs that were in there. Honestly, could probably do with putting in a few more.
      05-28-2016, 11:31 AM   #21
Spydeputy
Spydeputy's Avatar
Germany
205
If you would click on my link, you would see it's 5000K, daylight.
      05-28-2016, 11:40 AM   #22
BentZero
BentZero's Avatar
624
I saw that. Unfortunately that doesn't mean anything to me. :/ I'm wondering if you noticed much of a difference and is it worth it?
Build thread
Search this Thread:
Advanced Search
2addicts
