05-12-2016, 02:54 AM | #1 |
63
Rep 436
S55 Engine Swap
Question for the experts; Is S55 Engine swap possible on M2.
There are several complete S55 engines with low miles available (including ECU and sub-components). I am having the wild thought purchasing M2 and mounting S55 engine. Any ideas, thoughts on such possibility would be appreciated. |
05-12-2016, 04:19 AM | #2 |
237
Rep 551
05-12-2016, 04:21 AM | #3 |
237
Rep 551
05-12-2016, 07:00 AM | #4 | |
840
Rep 2,400
What are you trying to gain that a worlds-cheaper turbo upgrade won't get you?
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
05-12-2016, 06:00 PM | #7 | |
93
Rep 248
This is such a polarizing topic. In one camp are the "because awesome" group (when does a motor swap ever make significant performance, let alone financial sense). That's me, I don't like M cars because they're so practical, efficient, affordable, etc. they're about fun and how they make you feel. So I don't like that BMW "makes" me feel like I'm not getter a real M motor, all jokes about the s55 being a hyped up n55 aside In the other camp are the more realistic, practical folks who don't care if it's not an "S" motor. Slap a pure turbo in and a tune and you'll be keeping up with or bettering M4s. Need to be more like this group. Can't wait to test drive the M2... May end up parting with my s65 motor for it. Or... S65 swap? Stroker? |
05-12-2016, 08:13 PM | #8 |
Moderator
28913
Rep 13,048
For some speculation: http://f87.bimmerpost.com/forums/sho....php?t=1228342
///M is art ↔ Artemis
05-15-2016, 02:27 AM | #9 |
1712
Rep 5,108
Anything is possible. To get the engine installed in the car is the least problem here. It's fundamentally the same architecture, so expect engine mounts etc to be a direct swap.
Where you start facing issues will be with adapting the engine wiring harness needed for the S55 engine and mating it with the wiring harness in the M2. And then you need to get the proper software installed... Either by getting S55 software/mapping in the M2 dme or by using a S55 dme and have that set up with your M2's VIN etc. Since you can't order a S55 dme with a M2 VIN number from BMW, you need to change the VIN afterwards... And with the security and encryption built in, it takes some expertise and work to mate a S55 dme to your M2. If it's possible to remap a M2 dme with S55 software then that would be the better solution I guess. Modern cars that have CAN bus electric systems are also way more complicated to do these kinds of transplants on than a "good old" E30 with a M5 engine etc. Manhart in Germany do these kinds of engine swaps all the time. But it's expensive and time consuming. Expect it to cost just as much as you paid for the M2... The cost of the S55 engine is probably the least expensive part of the swap... (Unless you do all the labour, software work etc yourselves) |
06-01-2016, 06:24 PM | #11 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
I posted this over on 1addicts as this mostly pertains to the E82:
If you are planning on doing the swap, a few things have to be addressed. Firstly, steering. The subframe mounting can stay the same, but if you are planning on keeping the OEM plumbing for the turbos, it won't work. The rear turbo inlet will hit the frame, so custom fabrication is required. Secondly, the top-mounted heat exchanger won't clear the factory hood. It will either be necessary to have an aftermarket hood, or seek alternative cooling solutions (such as the typical front mounted intercooler with the secondary cooling system deleted). Then there is the steering. The location to bolt a power steering pump to the S55 interestingly enough exists, thus making either a swap to an existing F80/F82 possible, or a swap of the S55 into an older hydraulic steering vehicle less complicated. A "crossover" module for PT-CAN information will have to be installed and coded to intercept the bus information to convert to the older style cluster and FRM. Dynamic shifting has to be coded off, otherwise every time you go to downshift, it will redline the engine due to the transmission not having individual gear sensors. DSC will also need to be tweaked for different power input. There are other small physical compatibly issues, as well electrical/coding hurdles, but that's the basics of it. Also, You also have to double up the fuel feed lines and put in a T connection with a fuel line suitable for low pressure. The S55 has two high pressure fuel pumps that need equal feed pressure. In terms of cooling, the heat exchanger coolant reservoir must be relocated to the drivers side (instead of in the back) to clear the hood properly. If anyone has any more questions, feel free to message me.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
06-01-2016, 10:21 PM | #12 | |
601
Rep 836
