Creaking door seals?
05-04-2016, 02:41 PM | #1 |
54
Rep 215
Drives: E39 M5, F15 35d
I've noticed the door seals, or what sound slike door seals, on my '11 335D creak and groan any time the chassis is subject to the slightest twist or bend force, such as going in to a driveway or over a speedbump. All 4 doors seem to creak/groan, which I assumed was dry or unlubricated seals. So I bought a bottle of Gummi Pfledge and treated them all (on the doors and on the chassis) and assumed it would go away; it didn't. There's no discernable change at all. Anyone else experience this? It's driving me nuts!
05-04-2016, 03:15 PM | #2 | |
55
Rep 157
Drives: 2011 E90 6MT 335i
I tried the same stuff you did as well as quick wax and it would come back within the week. I tried an actual sealant, Blackfire wet diamond and the creaking goes away for months. I applied it to the felt but I'm guessing applying it to the actual paint that it's rubbing against will also work. Try applying a layer of sealant or real wax if you have some and see how that goes. I feel your pain because it was driving me nuts for months. Sounded like I was in a wooden ship. |
05-05-2016, 11:29 AM | #3 |
54
Rep 215
05-10-2016, 04:29 PM | #4 |
54
Rep 215
I waxed the door frames last night and it seems to have solved the problem. Thanks!
05-14-2016, 11:57 PM | #5 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
I use WD-40 and it works, applying wax on rubber is not good idea I guess???
05-16-2016, 12:00 AM | #6 | |
55
Rep 157
https://www.reddit.com/r/BMW/comment...inally_solved/ http://www.e90post.com/forums/showth...=406116&page=4 |
05-17-2016, 10:44 AM | #7 | |
54
Rep 215
The wax is applied to the paint on the inside of the door frames where either the felt or rubber seals touch the painted surface, not to the felt or rubber itself. |
05-17-2016, 05:52 PM | #8 | |
602
Rep 2,703
https://www.turnermotorsport.com/p-1...FcNehgodCz8ObQ |
05-17-2016, 06:50 PM | #9 | |
602
Rep 2,703
http://wd40specialist.com/products/silicone-lubricant/ yes regular wd-40 can be harmful |
05-18-2016, 10:56 AM | #10 | |
54
Rep 215
08-23-2021, 10:58 PM | #11 |
535
Rep 432
Still have yet to find a long term solution for this. I have noticed applying wax to the shadowline trim fixes the creaking for a few weeks......but it always comes back. Gummi pflege on the seals made no difference at all. Maybe ceramic coat the trim pieces? Anyone have better/other solutions to the wooden ship creek noise from the doors?
08-23-2021, 11:34 PM | #12 |
98
Rep 256
Have been putting up with this on my E90 and F30 for years. Tried silicone spray, nope. Then genuine BMW silicone remover to clean it off. Had the most success with gummi pflege, but still comes back eventually.
bmw335ie90535.00 |
08-24-2021, 02:30 PM | #13 |
858
Rep 1,363
Drives: 09 E90 335i M-Sport 6MT RWD
I ceramic coated all of mine (3 E90s with shadowline), It helps and its now to the point where I honestly notice it at all but its still there sometimes going in and out of uneven driveways
bmw335ie90535.00 |
10-01-2021, 05:48 AM | #14 |
98
Rep 256
Mine were getting creaky again. This time I’ve just scrubbed the living daylights out of the seals, felt and mating surfaces with the Genuine BMW Silicone Cleaner (used neat on a microfibre towel) and all is quiet again. I haven’t added anything else at all.
