Misfire after mhd flash
04-29-2016, 07:11 AM | #1 |
Rep 4
Afternoon. I've just installed mhd stage 1 on my stock 335i 07 Mt. What a difference it makes, it didn't last long though! after about 15 mins I took her out for a good run and as soon as I opened her up the engine light came on and she started misfiring . I'm getting a 29cd cylinder 1 code. But if I turn her off and on again she's back to normal. I'm hoping it's just the plugs. Anyone had similar?
04-29-2016, 07:46 AM | #2 |
46
Rep 505
Could be the ignition coil. I had to replace quite a few of mine when I installed the JB4.
Just pull the one from cylinder one and put it into Cylinder two then run the car again. If it misfires again and this time it says cylinder 2 you know its the coil. Easy to change and cheap enough to replace. |
04-29-2016, 08:06 AM | #3 |
175
Rep 1,596
The increased boost makes the mixture harder to ignite, so can highlight a coil or plug that was marginal before.
Giving it a fresh set of plugs is probably a good idea anyway, and as above, swap the coil around and see if the fault moves. |
