OptiCoat vs. Wheel Wax for Wheels
04-28-2016, 11:57 AM | #1 |
118
Rep 1,933
Hey guys,
I'm a newb when it comes to this, but I am looking for something to protect/seal my new wheels with so that it makes it easier to clean them. The wheels are Satin black (not sure if that matters in comparison to glossy wheels). Will OptiCoat and Wheel Wax have the same effect when it comes to cleaning? Anyone have any experience with this? Thanks in advance. |
04-28-2016, 05:00 PM | #2 |
360
Rep 5,052
While it is true that each of the mentioned products serve the same purpose (to protect the wheels), they are completely different products.
Opti-Coat is a nano coating that will bond to the surface of the wheel to provide durable protection which lasts years in most cases rather than weeks or maybe months if you are lucky with wheel wax. Nano coatings are also much more chemical resistant and heat resistant which helps provide an all together better layer of protection than traditional waxes or sealants. Opti-Coat, the product you mentioned, is only available through authorized professional installers and requires more prep work and time to apply than a traditional wheel wax or sealant. There are many great consumer wheel coatings that you can purchase and apply on your own if you do not wish to hire a professional to do it. Examples of wheel nano coatings available to consumers: CarPro DLUX, 22ple VM1 Extreme, GTechniq C5 Wheel Armor Let me know if you've got any questions! -Zach |
04-29-2016, 11:17 PM | #3 |
310
Rep 1,016
You can buy opti-coat here..
http://www.autopia-carcare.com/opti-coat.html#reviews The d-bag owners of opti-coat did a ton of shady stuff at the end of 2014. Honestly Id buy a different brand. They all do the same thing really. |
04-30-2016, 02:02 PM | #4 |
360
Rep 5,052
That is not opti-coat... as I mentioned, Opti-Coat is only available through authorized professional installers.
The product you are referring to is Optimum Gloss Coat. This is their consumer grade coating product. Product Review: Optimum Gloss-Coat by Zach McGovern -Zach |
05-03-2016, 09:44 AM | #6 | |
118
Rep 1,933
Thanks for all the suggestions everyone.
05-03-2016, 11:11 AM | #7 | |
360
Rep 5,052
The key is that you have to ensure you apply it evenly and then wipe away any high spots before they cure or else you may have a spot that is slightly shinier than the rest. Here are a couple examples of satin wheels we have recently coated... -Zach |
05-03-2016, 06:49 PM | #8 | |
310
Rep 1,016
05-03-2016, 10:27 PM | #9 | |
360
Rep 5,052
There used to be 2 versions of the product... Opti-Coat Pro and Opti-Coat 2.0. Opti-Coat 2.0 was available to consumers while Opti-Coat Pro was only available through authorized installers. Some detailers that were not Authorized Pro Installers were misleading customers by simply claiming they were "opti-coat installers" without clarifying that there was a pro version which was stronger and backed by a warranty. This was causing some major headaches among professional installers (I was one at the time). In order to help distinguish the professional products, Optimum stopped production of Opti-Coat 2.0 and replaced it with an updated version that was renamed to Optimum Gloss Coat. So, in reality they simply updated their consumer coating formula and changed the name... there were other changes associated with the professional program & installer requirements, but that is of no concern to consumers. Hope that helps clear things up -Zach |
05-04-2016, 01:52 AM | #10 | |
31
Rep 547
Its much like Cquartz and Cquartz Finest. The prep work and the overall process of the pro version is very labor intensive.
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
05-06-2016, 07:25 PM | #11 |
BimmerPost Supporting Vendor
1997
Rep 6,916
plus 1 on Zach's comments,
Opti Coat was a different product offered only to pros that were authorized and trained to use it. Opti Coat 2 and Opti Gloss coat are products for the diyers I would agree poor marketing on Optimum though. |
