Very Worried Pics Inside.....
04-28-2016, 04:48 AM | #1 |
g35x
105
Rep 630
Ok well here is my belt that idk why it was toasted the belt some plastic pulleys looked messed up and this shit was wound up on every plastic pulley there is on the car nothing was pulled from the harmonic balancer pulley. They youtube video is what makes me worry so much......
04-28-2016, 04:52 AM | #2 |
g35x
105
Rep 630
Got all pulleys off man that bottom one was a PITA with the air intake to turbo thing in the darn way ugh moved it all over the place lol
Also the ribbed part of the belt goes over a smooth pulley? Am I seeing this right? Top pulley labeled 2.....? Last edited by mightbaal; 04-28-2016 at 05:00 AM.. |
04-28-2016, 10:12 AM | #3 | |
295
Rep 2,202
also look to see if the belt or parts of did not get dragged in at the crank shaft seal.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
04-28-2016, 03:19 PM | #4 |
52
Rep 335
check your power steering pulley for damage. alot of the time this is caused by that pulley contacting the subframe, shredding the belt immediately or over time as the jagged edge tears into the belt. as mentioned above, there's a chance that the shredded belt can tear the front crank seal off the block, resulting in belt pieces in your oiling system. bad news.
04-28-2016, 03:28 PM | #6 |
g35x
105
Rep 630
Also this looks like a smooth pulley this is the tensioner...
https://www.amazon.com/gp/aw/d/B00HC..._st_dp_summary |
04-28-2016, 04:12 PM | #7 |
52
Rep 335
aside from swapping out your front subframe with the updated part from BMW, the general consensus is upgrading to the 335is motor mounts can help prevent this. I upgraded both mounts to the 335is part and haven't had any issues up to this point. It's been a little over a year since I replaced them, so far so good.
04-28-2016, 04:14 PM | #8 |
52
Rep 335
both pulleys on the tensioner are smooth, so yes the ribbed side of the belt will loop around the smooth upper pulley.
05-01-2016, 08:45 AM | #10 |
1658
Rep 4,891
That usually means that a pulley is wobbling, or the bearings are bad in the idlers (wobbling).
Had a similar issue with the supercharger on my truck when the pulley came loose. |
05-01-2016, 09:55 AM | #11 | |
167
Rep 1,415
05-01-2016, 11:01 AM | #12 |
210
Rep 563
My belt shreeded as well with the updated front subframe the cause of mine was a siezed alternator clutch pulley
the shop in that video obviously know nothing about n54 belt failure because it probably almost never is caused by the belt itself |
05-01-2016, 11:12 AM | #13 |
77
Rep 334
