03-12-2008, 06:37 AM | #1 |
yodog
196
Rep 5,026
Lowering Springs on EDC
Do lowering springs like the H&R Sports that are supposed to work with EDC have a negative effect on the EDC shock life?
Do you guys think the performance could actually decrease, and only the "look" increase? Would warrenty cover anything that went wrong with EDC if you have lowering springs? |
03-12-2008, 01:31 PM | #2 |
83
Rep 411
I have driven/owned various M's (M3 E46, M6, M3 E92) and all lowered them with springs only from Hartge. Never had a single problem resulting from that, although quite a few people will make you believe otherwise. They were specifically developed to work with the oem shocks.
03-12-2008, 01:54 PM | #3 |
609
Rep 10,407
FYI this has been discussed ad nauseum here on the forum. Try a google search instead of the forums built in search. Try this link and look at the syntax of the search (you just add site:m3post.com to the end of your search).
The quick answer is that EDC does not care what springs you use. Although the damping rates are optimized for the existing springs as long as your springs are not unrealistically short or stiff all will be fine. |
03-12-2008, 02:20 PM | #4 |
Moderator / European Editor
1492
Rep 6,755
Sorry for OT:
Well, you told so many times how to use the google search and I never mentioned this was totally new to me. Thanks, Sw! Best regards, south
03-12-2008, 05:34 PM | #5 |
609
Rep 10,407
It is really powerful when you use the additional google capabilities that are not present in the M3post.com such as boolean logic. I almost never use the M3post.com search function.
03-12-2008, 05:47 PM | #6 | |
45
Rep 175
2022 M240i | Brooklyn Gray | Red Leather | Black 791M rim| Black trim | HK | Premium | M Lum
03-12-2008, 06:38 PM | #7 | |
Commander-In-Chief
2067
Rep 8,898
I just sent Ground Control and inquiry about this.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-12-2008, 10:46 PM | #8 |
O! So Sour!!
549
Rep 15,615
Drives: Fast 240z / Slow M3
looks like i might have to put some sandbags or something in my trunk
03-12-2008, 11:51 PM | #9 |
Dr. Octagon
260
Rep 1,919
The drop is minimal on the H&R's. The additional wear on the stock shocks will be negligible. Stock height is unacceptable.
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
03-13-2008, 06:02 AM | #10 |
yodog
196
Rep 5,026
If the life expectancy isn't shortened by a measurable amount then h&r sport springs it is. The m3 would be perfect with a drop of about like 1"-2".
03-13-2008, 11:34 AM | #11 |
Commander-In-Chief
2067
Rep 8,898
Ground Control lowering springs for EDC
I inquired with Ground Control if they would offer lowering springs for the M3 EDC.
"Yes. definitely, it has been popular for the e60M5, and of course I expect moreso for the M3. The upper perch in front is the same as e46 M3 and the rear requires a new upper mount and perch." Jay Morris
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 03-13-2008 at 01:53 PM.. |
03-13-2008, 12:00 PM | #12 | |
823
Rep 46,029
03-13-2008, 05:11 PM | #13 | |
yodog
196
Rep 5,026
04-10-2008, 02:09 AM | #14 |
Dr. Octagon
260
Rep 1,919
difference between stock...
OC ///M
04-10-2008, 06:56 AM | #15 |
Reincarnated
245
Rep 4,227
Interesting, OC! More info!
04-10-2008, 08:26 AM | #16 |
Commander-In-Chief
2067
Rep 8,898
No clue at this point. Springs are pretty inexpensive. Don't know if anything can be done with the perch; might just have to use stock. Here's pics of front and rear setup:
04-10-2008, 08:41 AM | #17 |
1912
Rep 4,128
Drives: M235i & G30 540i
If you read about some of the problems from m5board.com with springs and EDC you will notice that the problems were related to the H&R springs. I haven't seen anyone post about a problem with Dinan springs or Hartge springs.
That leads me to think that its ostensible that H&R may have a problem with the M3 EDC as well. JMHO
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
04-10-2008, 10:05 AM | #18 | |
Commander-In-Chief
2067
Rep 8,898
04-10-2008, 10:09 AM | #19 |
1912
Rep 4,128
Agreed. However using Dinan springs will not void the EDC warranty.
04-10-2008, 10:27 AM | #20 |
Commander-In-Chief
2067
Rep 8,898
Well, technically, the factory warranty will be replaced by the Dinan warranty. That's one reason Dinan parts are so expensive. May be worth it in this case.
04-10-2008, 10:30 AM | #21 | |
1912
Rep 4,128
I'll have to price the Dinan springs cause this is probably the only way I'd go just to get away from the hassle of the possibilities that can go wrong.
04-10-2008, 11:02 AM | #22 |
O! So Sour!!
549
Rep 15,615
How much are Dinan springs for the E92 M3?
