e90 Water Pump Failure?
04-26-2016, 10:54 AM | #1 |
Rep 89
Recently when doing my regular drive, I got a yellow high temp light, followed by a red high temp light within a minute. I pulled over and shut the car down and noticed the fan was running full speed. I waited about 15minutes for the car to cool down a bit, so I could limp my way home (Less than a mile).
When I turned the car back on, The fan turned off and I had no temp warning lights. The rest of my drive was perfectly fine. I waited to let the car cool down to check coolant and I am pretty close to the minimum mark. I then decided to test the pump as i've seen. Turn car on, but not engine. Turn heat to max and fan speed to lowest. The pump sounds like this. Note* THIS VIDEO IS NOT MINE. My pump sounds very similar to this, but it does pump still. Now it pumps normally and then seems like it slows down to a stop, and starts back up and repeats. Is this apart of the normal cycle? or is that the pump failing? Also is that actually the sound of the pump failing? I have no idea of what it should sound like. Any help is appreciated. |
04-26-2016, 11:25 AM | #2 |
266
Rep 952
The statistics tell us that your waterpump is failing because it has failed in this same way for so many other 335 owners. The failing pump is not always a mechanical failure. It has often been a failure of the waterpump control board.
Mine failed intermittently at first as well. The sounds I heard were the radiator fans running all the time due to the waterpump not circulating water.
bone stock
04-26-2016, 02:12 PM | #3 |
Where'd my VTEC go?
481
Rep 6,067
Overheating is a telltale sign it's failing. Get it replaced before it really strands you.
04-27-2016, 03:28 PM | #5 | |
52
Rep 335
04-27-2016, 03:35 PM | #6 |
52
Rep 361
When mine failed, there were no warning lights...
...but I heard a loud whirring noise and opened my window to discover it was coming from under my hood (almost sounded like someone was running a lawn mower aside of my car). I came on here for advice and everyone said to get it replaced, and they were correct.
That car had nearly 120,000 miles on it when the pump failed, so I was a lucky one. Others said there's lasted 50,000 or so. |
04-27-2016, 04:32 PM | #7 | |
52
Rep 335
