04-25-2016, 06:40 AM | #1 |
105
Rep 265
Tyre repair kit + plug kit
Hi,
I have replaced my RFT with non-RFT tyres. So now I need something in case of a flat (I have no spare tyre in the trunk). I would purchase a spare tyre if there was room for it, but sadly there are none. So I'm looking at purchasing a tyre repair kit, with a compressor and sealant. I know BMW does sell their own variant, but it's a bit expensive for what it is. So I found this: http://www.amazon.com/Slime-40013-Sm...slime+tyre+kit Very good reviews and also looks like it is possible to wash the Slime away from the wheel when replacing the tyre. This is not the most important part, as I want a tyre plug kit too (which I will use first, before trying slime). What tyre plug kit is the best you can get for a good price? Thank you very much! |
04-25-2016, 06:59 AM | #3 |
3079
Rep 5,579
I like a small bicycle pump to inflate my tire's.
It can be difficult to pull a nail and press in a plug with ( particularly a rear ) tire mounted on the car but it is doable. |
04-25-2016, 08:52 AM | #4 |
38
Rep 378
check out the continental conti comfortkit
2022 Audi RS5 Sportback
SOLD 2013 BMW 335i M Sport Xdrive / MPPK / MPE / Alpine White / Black Dakota Leather / M Sport Brake / 19"Style 403m / M Perf Diffuser |
04-25-2016, 07:52 PM | #5 |
66
Rep 228
I've successfully used Dynaplug in the past. In my opinion it's worth it to get the process version with the wide end, as it helps in getting more power behind it when you're shoving the plug in.
04-25-2016, 08:47 PM | #6 |
#buildnotbought
11033
Rep 4,920
If you want to set a tyre plug you also probably need a small jack in the car (and wheelwrench). Finding the leak with the wheel on the car...might be a challenge.
Those small cheap 12v tyre compressors take an age to fill the tyre. As for tyre plug kits, I've used the cheapest china plug kits with success. Like these http://www.ebay.com/itm/Safety-Car-B...-/281993211117 A small jack, wrench, plug kit and compressor probably take up the same amount of space as a slime kit
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
04-25-2016, 08:53 PM | #7 |
225
Rep 807
Drives: 2011 335is 6MT
Have you looked at a low cost roadside service plan? I pay $7 per 6 months, or $1.17/month, on each of our cars through our insurance carrier (USAA).
It includes: Towing to the nearest repair facility Gas delivery Changing tires Performing labor where the breakdown took place Popping locks by a locksmith |
04-25-2016, 08:58 PM | #8 |
225
Rep 807
From their webste:
Note: This product cannot be used on vehicles equipped with direct tire pressure monitoring sensors in the wheels. Use of this product on these vehicles could result in damage to the sensor inside the wheel. Please contact your sales specialist at Tire Rack for more information. |
04-25-2016, 09:28 PM | #9 |
913
Rep 1,850
All you need is one of those electric compressors and a plug kit, plus jack and tools to remove a wheel to facilitate plugging. Wheel removal / jacking isn't strictly necessary but good luck plugging a tire on the car. It can be done but it would be very difficult.
The electric compressors take forever to fill a tire, especially one that plugs into a lighter socket, so I recommend a heavier duty comppressor from amazon that will clip onto your battery. Fill with the car running if you have any concerns about the battery capacity. |
04-25-2016, 09:43 PM | #10 | |
731
Rep 1,472
I have this kit in my trunk, can't say how effective it is since I haven't used it, but read a bit before I purchased, seems OK. |
04-26-2016, 12:21 AM | #11 |
4987
Rep 11,891
bike pump, you're not kidding are you?
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
04-26-2016, 05:51 AM | #14 | |
1019
Rep 638
I've found that actually running the engine with the cig.lighter compressor, actually gives you more power, I always only do it that way
04-26-2016, 06:01 AM | #15 |
European Editor
10624
Rep 22,992
Conti Comfort Kit...
The TireRack.com has some nice kits...
Conti Comfort Kit... http://tires.tirerack.com/tires/Conti%20Comfort%20Kit
04-26-2016, 06:48 AM | #16 |
3079
Rep 5,579
Not a mini but doesn't take up much room.
04-26-2016, 09:03 AM | #17 |
687
Rep 2,770
Have you EVER tried to use that to fill the tire from flat before. You will litteraly grow old and die before you get to half pressure. That pump does not have near the capacity to fill a car tire. Simple consider the volume of a car tire as compared to a bike tire.
Piece of advice to all, always try out your emergency plan/provisions under controlled conditions first to verify they work correctly.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
04-26-2016, 09:14 AM | #18 |
#buildnotbought
11033
Rep 4,920
^it;ll be a lot quicker than those little 12v compressors I think.
I estimate you need about 300 strokes from that bicycle hand pump to get a tyre from empty to full pressure. You can do that in about 5-10 minutes.
04-26-2016, 09:23 AM | #19 | |
731
Rep 1,472
I don't understand the need for pump or repair kit thought. While I think that yes, it'll take a long with the hand pump to get it to pressure it's possible to do so. Pain, yes, but it can be done. What I don't get is, who will pull on the side of the road with flat tire, and try to use "repair" kit on the spot, then inflate it with the pump? Locating the puncture, repairing it safely, doesn't seem like realistic scenario to me - pump is least of your problems at that point. I think that if you ditch run flats (I did), kits like, or similar to what we recommended (Continental) are the only option - and you can only hope it works. |
04-26-2016, 09:27 AM | #20 | |
687
Rep 2,770
Seriously, if the plan is to use this in an emergency you should try it out beforehand so you don't discover that it doesn't work when you are on the side of the freeway in the pouring rain.
04-26-2016, 09:37 AM | #21 |
4465
Rep 9,160
Unless we're talking about filling a Ford Raptor tire, a bike pump is fine. Volume of a low profile car tire isn't all that much greater than a fat bike tire and the stiff sidewalks help too. Are the naysayers speaking from experience or just something vaguely remembered from a high school physics class? I've filled numerous car tires from flat with a Silca. 10-15 strokes per PSI is about right. Not fast, but unless you're on a donut and non filter cigarette diet, it won't hurt you.
04-26-2016, 09:49 AM | #22 | |
#buildnotbought
11033
Rep 4,920
The area where I live (netherlands) is probably the most densily bicycle owned country in the world (so a bicycle tyre pump is here one of the most common household things ) Obviously if you have shop air you use that, but in an emergency its doable and faster than one of those cheap mini 12v compressors as I wrote (but that doesnt cost any physical energy of course so that has its plus too ). Having a good quality bicycle pump helps. dual cylinder footpumps ftw.
