325i BHP upgrade
04-21-2016, 09:59 AM | #1 |
48
Rep 313
325i BHP upgrade
Hi Guys,
I was happy with the speed of my car etc and wasn't planning to do any engine type upgrades but I have found this: http://mosselmanturbo.com/remapping-...25i-e90-218hp/ Has anyone done this to their car? i cant believe you can get 272bhp out of a 325i which is 218bhp. if anyone has this how are you finding it? Can you feel the difference straight away? Very tempted by this! |
04-21-2016, 10:33 AM | #2 |
146
Rep 2,337
It's £1200 though + fitting. The 325i block is the same as the 330i. This upgrade has been done by a few. It's not bad for the money, but at the same time, you could just get a 330i.
04-21-2016, 10:45 AM | #3 |
48
Rep 313
Ahh ok. But I have a 325i so rather than source a 330i and do all the upgrades to it I could just potentially get this. for the price it sounds like a decent option.
04-21-2016, 11:06 AM | #4 | |
146
Rep 2,337
But yeah in most cases it's better to just swallow the pill and swap. The 330i has bigger brakes I think too and there will most likely be more than that to add to the list. |
04-21-2016, 02:09 PM | #5 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
I looked at this, but honestly thought it was overpriced. You will also have the possible problem of DISA flaps rattling and/or disintegrating (the 325i doesn't have these). And as you said in your first post OP, there's not much wrong with the 325i engine anyway.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-22-2016, 12:59 AM | #7 |
13347
Rep 7,484
04-22-2016, 03:04 AM | #8 |
146
Rep 2,337
04-22-2016, 03:07 AM | #9 | |||
48
Rep 313
BTW what colour is your car is that the same wrap as mine or a painted blue. I cant tell by the avatar! Quote:
Just to double check. My car is a E93 pre lci but it says I have an N53 based on my vin. Is there a chance thats not correct? As i know this mod is only available for N53 engines |
04-22-2016, 03:10 AM | #10 |
616
Rep 3,194
True, but there's also a purity about the 325i in these days of turbocharging and digital everything, to have just a straight inlet manifold and, other than VANOS, an 'analogue' engine is nice (IMHO). And there aren't many 3 litre engines that will give 40+ on a run and a range of over 500 miles to a tank. A true GT car...
But then I am hopelessly biased!
04-22-2016, 03:59 AM | #11 |
13347
Rep 7,484
04-22-2016, 04:08 AM | #12 |
48
Rep 313
04-22-2016, 04:09 AM | #13 |
10
Rep 127
I read about this when i was looking to buy one and the manifolds and disa valve can be bought on fleabay, fitted by yourself then any remapper can then map it.
http://www.e90post.com/forums/showthread.php?t=372973 - The above thread also has a good DIY link! |
04-22-2016, 05:48 AM | #14 | |
123
Rep 604
It took MStyle most of the day due to the manifold swap over and then waiting for car to be hooked up to Mosselman for the remap, which is logged to the VIN. You have an option to buy the remap on a USB in case it gets wiped by an update. If you don't get this you can go in once for free to get it reapplied if required. The manifold components replaced are all OEM from a 330i. It is expensive, but you will defiantly notice a difference in power. I did not notice a drop in fuel consumption. Its runs more efficiently as it is not nobbled, which offsets the fuel consumption when you floor it. If you want to keep the car, but want more poke I'd say it is worth it as you will loose more by trading in your car. The good thing is you are not stressing the car by tuning it. You are simply un-nobbling it to release the power it should have had in the first place. It was nobbled for German tax banding. |
04-22-2016, 05:51 AM | #15 |
146
Rep 2,337
Good point Nickos
- Manifold on leebman http://www.leebmann24.de/ansaugleitu...617559523.html 500 euros if you say you are e90post member. I think around £700-800 total for all the parts if you shop around and buy from the right places. |
04-22-2016, 07:25 AM | #16 | |||
48
Rep 313
04-22-2016, 09:55 AM | #17 |
175
Rep 1,596
the question is if mosselman will supply the remap to you if you dont get the kit from them.
The reality is you should be able to flash on the BMW factory software for free, but not came across anyone who has tried that yet. Could be a pretty cheap conversion if you picked up a used manifold etc. |
04-22-2016, 10:01 AM | #18 |
187
Rep 1,247
It might be worth just getting a remap as it looks like the bulk of the gains are in the software.
http://www.more-bhp.com/bmw-3-series...ecu-remap.html |
04-22-2016, 11:34 AM | #19 |
13347
Rep 7,484
04-22-2016, 11:39 AM | #20 | |
616
Rep 3,194
04-22-2016, 02:10 PM | #21 | ||
187
Rep 1,247
I'm not suggesting more-bhp's figures are correct; I just used that site as they're not known as Cowboys. They claim to get the 325i to 262bhp and the 330i to 282bhp which gives a good benchmark for the effect of the inlet at 20bhp. Sounds relatively feasible and much cheaper than the Mosselman kit. |
04-25-2016, 06:57 AM | #22 | |
48
Rep 313
