330D M57N2 Glow Plug Controller - diy or advice?
04-19-2016, 04:29 PM | #1 | ||
16
Rep 107
OK, with the help of the forum I have the knowledge to replace the EGR and main thermostats. I plan to do the work at the same time with the brunt of the work being the main thermostat.
I also need to replace the glow plug controller unit. I can't seem to find a DIY or anything that tells me how hard/easy it is for my engine apart from this thread: http://www.bimmerforums.co.uk/forum/...blems-t124363/ where someone states: Quote:
Thanks Dan |
04-20-2016, 03:38 PM | #4 |
16
Rep 107
Wow, thanks for that find, didn't think to look for 530D, doh! Well that look like a lot less than the 2 hours quoted or the 4 hours quoted to do this and both stats!
04-20-2016, 04:16 PM | #5 |
103
Rep 709
Drives: BMW M4
I did this in my e90 m57 33pd without removing anything iirc. Didnt drain the coolant either. was tricky but did it. Have to be good wirh a torch and fingertips to get the bolts in. I may have undone the dipstick but thats about it
05-07-2016, 09:52 AM | #7 |
16
Rep 107
Well I got round to replacing just the controller with a genuine part from Cotswold BMW.
What a PITA job, not technically difficult just fiddly and my hands are now raw with grazes...anyway, afterwards I ran Carly, cleared up existing fault codes and have re-run a few times to be sure and STILL, all 6 glow plugs are coming up faulty. Unless the unit is faulty or actually ALL my glow plugs need changing, I can't see what else it could be. I'm assuming if it was a connection problem it wouldn't work at all. Not happy, although if this has happened and I had paid for labour I would have been more p**sed off! |
05-07-2016, 11:56 AM | #8 |
103
Rep 709
Drives: BMW M4
Only thing is to remove all six and check them with a multimeter Inlet manifold off etc. Time consuming as hell job.
2014 M4. Non-ZCP. GTS EDC, DCT & Diff software with eibachs... gamechanger.
05-07-2016, 12:48 PM | #9 |
16
Rep 107
Bugger. That is quite an involved job after looking at youtube, I might as well get them all replaced by the indie.
I did clock a post on a forum where a 330D owner said his errors disappeared only after the controller and all plugs were changed although that could mean he tried the controller first when maybe it didn't need to be changed and was all the plugs after all. My car is on 155k and I've had it since 80k / 4 years and I can't see any evidence of it having plugs changed. Not sure how likely, if they are at the end of their life, that they would get to the same failing point at roughly the same time. Dan |
05-07-2016, 12:54 PM | #10 |
16
Rep 107
LOL, the OP on this thread had exactly the same issues as me:
http://www.bimmerforums.co.uk/forum/...-code-t129796/ So the plan of action is get the plugs changed by the indie but still doing the thermostats myself! |
