E92 335d - 313 alloys rubbing on the rears
04-17-2016, 06:22 PM | #1 |
98
Rep 477
Guys can i ask you all something..
I had previously Bbs lm reps on my e92 335d. They were 19" with 8.5 on the fronts and 9.5 rears and no rubbing with the spacers i currently have. (Car is lowered on h&r sport springs) I sold those alloys and bought bmw 313 reps from ********. Again 19" and same offsets, however the rear is rubbing when i go over bumps! What do i do? And although same size as my old wheels, these wheels do look like the rears stick out much more then my previous set. What is the solution? Run the alloys with no spacers on the rears?
Follow My e92 335 AW- SNOW WHITE PROJECT BUILD
http://www.e90post.com/forums/showthread.php?t=952654 photo uploading websites |
04-18-2016, 01:22 AM | #2 |
448
Rep 3,312
I'd certainly check the offsets and widths to confirm. If the same then you shouldn't have any issues but certainly sounds like the offset on the rears is lower and causing the rims to protrude more than your previous set.
As a temp solution yes just remove the spacers. What size spacers are you running?
E92 335i / M3 Hybrid - The Build
04-18-2016, 04:56 AM | #3 |
96
Rep 828
sounds to me like the offsets are different.
04-18-2016, 05:19 AM | #4 |
175
Rep 1,596
if the rears are sticking out more, the offset has to be different or the wheel is wider.
Reduce the rear spacing until they're sitting the same as the old ones did! |
04-18-2016, 04:22 PM | #5 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Have the rear arches rolled. I had the same issue and got this done. Actually, only a small area towards the rear of the arch needed to be rolled.
If you take the wheel off and look inside the arch you'll see evidence of the rubbing which will show you which bit needs to be rolled.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-19-2016, 02:10 PM | #6 | |
28
Rep 306
How much was this if you don't mind me asking? Thinking of having my rears done as I've got a new set of wheels on the way at weekend |
04-19-2016, 06:00 PM | #7 |
98
Rep 477
Update
Late reply due to work reasons, but i finally had a chance to jack up the car, remove the wheels an take the spacers off the rears. To my suprise it doesnt look too bad without them and the rubbing has completly stopped aswell
04-20-2016, 02:59 AM | #8 |
616
Rep 3,194
Sorry, so long ago I can't recall. Not a huge amount as I remember. Your main issue will be finding someone who can do it for you!
04-20-2016, 04:21 AM | #9 |
28
Rep 306
04-20-2016, 05:46 AM | #10 |
680
Rep 2,444
Drives: 2018 630iGT sport
04-20-2016, 02:44 PM | #11 | |
28
Rep 306
04-20-2016, 03:13 PM | #12 |
680
Rep 2,444
Fair enough. They're mobile though?
These guys have been doing this work for years, and are highly recommended across many forums. |
