Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Xi front ball joint?
      04-12-2016, 03:54 PM   #1
Needbmwpartzz
Needbmwpartzz's Avatar
851
Drives: 2009 bmw 328i x-drive
Does anyone have the correct way or sure method to extract ball joint from knuckle on front of e90 x-drive.....going to tackle this job soon but still unsure how to proceed even after reading here.
TIA
      04-12-2016, 07:37 PM   #2
Needbmwpartzz
851
Bump.....
Anyone?
      04-13-2016, 08:19 AM   #3
vapore0n
40
Drives: 2010 335i
http://www.pelicanparts.com/BMW/tech...eplacement.htm
That procedure shows how to remove the ball joint. Quite easy.
      04-13-2016, 08:25 AM   #4
Needbmwpartzz
851
Thanks for the link but that is only for non-xdrive models.
The ball joint is pressed/bolted to knuckle...and a bigger pain to remove.
I'm just wondering if there's a specific puller that extract it without brute force.
      04-13-2016, 08:48 AM   #5
pierop
16
Drives: 325i e90
You could use the universal harbor freight wheel hub bearing press to remove and press, additionally you could freeze the ball joint, apply some lubricant and heat up the knuckle right before pressing.
http://www.harborfreight.com/fwd-fro...ers-66829.html
      04-13-2016, 10:54 AM   #6
All4bigAl
All4bigAl's Avatar
Drives: E93 M3, F10 550, E70 X5
Assuming you're talking about the wishbone and not the thrust arm... I just did this last week on my xi. Left side went great. Right side PITA. I used a press tool similar to the Harbor Freight one, but if I had to do it again I'd just order the whole control arm. I purchased an 1-1/2" black iron pipe nipple from HD since there isn't a collar in the kit that fits snugly onto the ball joint. The right side I tried heat, hammer, you name it and it wouldn't come out. Finally just let it soak with penetrating fluid for a few hours, gave it one last shot and it popped out. Be careful that the new ball joint goes in straight when you are pressing it in. Lot's of soap helps. The suspension needs to be loaded when you tighten the nut/bolt for the ball joint. You'll need an alignment after.
Side note: After removal and inspection I actually think my "old" one was just fine.
      04-13-2016, 11:44 AM   #7
PhaseP
1007
Drives: 325XI
You guys are talking different parts than op and using wrong terminology.
      04-13-2016, 11:52 AM   #8
Needbmwpartzz
851
Yup....I'm talking about ball joint that TS attaches to.
Guess I'm just going to wing it and hope it comes off easy!
      04-13-2016, 01:18 PM   #9
All4bigAl
All4bigAl's Avatar
My bad. Sorry about that!!
      04-13-2016, 02:00 PM   #10
Needbmwpartzz
851
No worries....so many suspension part names it's confusing unless your looking at diagrams with exploded view and numbered legends.
Here's an appreciate for your effort
      04-15-2016, 07:55 PM   #11
cranelec
105
Drives: BMW
I did it my way!
TIA
Replaced these on my wife's 2007 328xi. I used a MAPP gas torch + air hammer/chisel. Need to wrap heat susceptible areas with wet cloths & aluminum foil. (I used flexible heat shield material available at local big box home improvement stores.
mike
      04-15-2016, 10:39 PM   #12
Needbmwpartzz
851
TIA
mike
That's what I figured needed to be done.
How long it take with the air chisel,come out easily or did they need to be destroyed?
      04-16-2016, 07:16 AM   #13
Greyfox
Greyfox's Avatar
1208
Drives: 2007 328xi E91 - 330k+ (miles)
And be damn careful of the torx bolts. Went to do mine and two of those idiot things stripped even after applying heat.
Took it to a local indy shop at that point. They had them out in ~2 hours. I gave the mechanic an extra $50 for saving my ass.
      04-16-2016, 06:29 PM   #14
Needbmwpartzz
851
Yup....tried and failed to get the balls out.....in not equipped with the proper air tools to get them out....I tried but no cigar.....can't swing hammer with the required force in wheel well while car is on jacks ti budge them....mine turned out to still be in good shape anyways.....however the tension strut replacement made my car feel brand need again.....best repair I've done to restore that BMW handling....so awesome again
      04-17-2016, 01:13 PM   #15
cranelec
105
Drives: BMW
Without air chisel & heat: 6 hours and never came out (15 minutes once heat was applied)
Other Ball Joint: 45 minutes with air chisel & heat.
Please read the post about the torx bolts. I bought a Lisle impact torx set. By the second ball joint, I had destroyed the bit. DON"T TRUST HARBOR FREIGHT QUALITY TORX BITS.
Over the course of several days, apply heat, cool, and quality penetrant like Silikroil. You will destroy the ball joint but even OEM are relatively cheap.
Last piece of advice, make sure you LOAD UP
your radius & thrust arms prior to final assembly. If you don't load them up, you will destroy them before you get to a stealership to align the car.
mike
