Question for 420bhp (ish) 335D owners.
04-12-2016, 02:54 PM | #1 |
21
Rep 201
Hi All,
A little bored of my E92 330D 245 and was looking into getting a 335D 285 and going for the two new turbo option / associated kit to get it around 420bhp. Question to the people who are running this set up - is it usable or do you struggle getting the power down? Also - do they kick a lot of smoke out without the DPF? Anyone got any max figures whilst leaving the DPF on? |
04-13-2016, 02:08 AM | #3 | |
400
Rep 5,623
It is 100% useable. On motorways a slight squeeze of the throttle and you're already above the speed limit. On local roads the power can still be fully felt, whilst staying under the limit. The torque, 835nm, is just immense and can be felt whenever you drive, and not neccessarily at WOT. From a standing start, you can not go WOT obviously, but its quite easy to judge the power so you don't wheel spin. The first two gears need managing but after that you can go all the way. Just bear in mind you will have to look at handling upgrades and probably an LSD would help a lot. There is some smoke on the 420bhp map i have. Not a lot, but a puff only when going WOT. i also have a 350bhp map which i can switch to, and this has zero smoke. |
04-13-2016, 05:31 AM | #4 | |
283
Rep 2,343
I'd love to see you run water/meth on it. I think that would really blow you away.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
04-13-2016, 06:16 AM | #5 |
659
Rep 1,239
Yeh I'm about the 400bhp mark with stock turbos , Wagner fmic, dpf delete, remap and water meth, although the water meth when on reaks like fooook lol , it's usable , the 335d is a weighty car , my mates m135 400bhp thing is really snaky , a LSD will be a big benefit to how it puts the power down , aswell as decent tyres
Mapping also has a lot to do with it ! |
04-13-2016, 02:09 PM | #6 | ||
400
Rep 5,623
I think meth would take it close to 470-490bhp, and probably 900nm+ as a guess, which would be awesome. Just a bit wary of the gearbox. But i really want to sort out the handling first, hoping m3 arms, solid SF bushes and an LSD should do it, so may leave meth until its all done, which will probably take ages lol |
04-14-2016, 03:30 AM | #7 | |
283
Rep 2,343
04-14-2016, 03:31 AM | #8 | |
283
Rep 2,343
04-14-2016, 02:35 PM | #9 |
21
Rep 201
Cheers for the replies all. Problem is I don't know if I could part with my immaculately maintained E92 330D, especially after fitting logic 7 to it etc. Finding a 335D with the same spec and colour wouldn't be easy.
Decisions lol!! |
04-21-2016, 07:08 PM | #10 |
659
Rep 1,239
04-22-2016, 05:59 AM | #11 |
16
Rep 209
I am going for this upgrade also I cannot wait. This upgrade seems to be getting alot more common now. And I am still to hear of a gearbox failure
04-22-2016, 06:31 AM | #12 | |
400
Rep 5,623
I also haven't heard of gearbox failures, touchwood it won't happen. |
04-23-2016, 10:04 AM | #13 | |
16
Rep 209
I am still undecided where I would go for the new remap though. |
04-23-2016, 02:28 PM | #14 | ||
400
Rep 5,623
With the remapping, i would recommend Ecotune as they do this upgrade, but i'm not sure if they would be willing to do it on a car with the parts fitted already... |
04-23-2016, 02:34 PM | #15 | |
175
Rep 1,596
Much like the upgrade on the 325i where the 330i inlet manifold is swapped in and the ECU mapped to suit. Not much info available on doing it though |
04-23-2016, 02:54 PM | #16 | ||
400
Rep 5,623
I thought the 335d turbos worked differently as there are 2, or is the big 335d turbo the same ish as the single 330d one? |
04-23-2016, 04:15 PM | #17 |
175
Rep 1,596
Like i say, in theory theres no reason why it couldnt.
However your right, the turbos do use different actuators, so there would be some modifications to the wiring. Certainly not plug and play, however its not impossible. Afterall, if folk can wire in a JB4 on a 335i, theres no reason why you couldnt wire in the extra solenoids to control the 335d turbo. Theres other issues to consider as well, like can the 330d DME run the 335d software. I'm surprised its not been tried, but like i say, in theory its all doable. Worst case you'd need a 335d DME and engine harness. |
04-24-2016, 02:57 AM | #18 |
16
Rep 209
Here is the link for the gearbox company mate it is actually local to me in Dartford
www.reconditionedgearboxes.com I might give ecotune a ring and see what they say regarding the remap. If they are not willing to do it I will probably go to bwchiptune |
04-24-2016, 04:32 AM | #19 |
175
Rep 1,596
FWIW, i had a look at the wiring diagrams on the 330d and 335d last night.
The 330d uses one pin from the ECU to drive the turbo actuator (pin 93) The 335d also uses pin 93, which it connects to the turbine bypass valve. The 335d then has two further connections on pin 17 and 20, connected to the wastegate valve and compressor bypass valve respectively. Adding those two pins to the ECU harness would be a relatively easy job. Ofcourse the question still stands if the 330d DME has the hardware internally to drive those pins, and thus just needs loaded with 335d software, or if you'd need the 335d DME. Would probably need a tuner to try loading the 335d software onto the 330d ecu and see what happened. As a futher point, making this discussion all a bit pointless, is the conversion would only be possible on M57 330d's and the OP looks to have an N57! Last edited by Aragorn30d; 04-24-2016 at 04:41 AM.. |
04-27-2016, 08:48 AM | #20 | |
21
Rep 201
Mines a 330D 245PS (not sure which engine model off the top of my head). Would be absolutely awesome if I could get 420BHP out of it though with the 335D mods!! |
04-27-2016, 09:06 AM | #21 |
175
Rep 1,596
yeh the 245 engine is the N57, so i've no idea if the 335d parts would even bolt on, and the DME is almost certainly different.
They did build a twin turbo N57, but it was never fitted to an E90. The F10 and F01 used it as well as the xDrive40d in the X5/6. Theres perhaps some scope to use those parts, you'd really need to speak to a tuner though about wether they could tune the ECU properly to match up with the twin turbo system. |
04-27-2016, 09:28 AM | #22 | |
21
Rep 201
