Subframe Rust
04-11-2016, 03:50 PM | #1 |
152
Rep 645
Subframe Rust
Hey guys,
I was having a nosey under the rear of the car last night with a flashlight, just to check everything looked okay, and noticed a few areas of surface rust on the back side of the rear subframe. The main spots are on the subframe itself just above / around where the main rear aluminium arm bolts to the subframe, and are around the size of a 1 pound coin. It wasn't deep rust - more just flaky surface rust, where if you scraped with a screwdriver flat-head you'd get a paper thin flake fall off (sorry that's the best description I can think of!). There are also a couple of other small spots on the seam welds in the same area. I purchased the car in 2013 and it has since spent its life in NZ where we don't salt our roads. I'm guessing the 6 years in the UK has meant it was exposed to salt. I can't see a spot of rust anywhere else on the car. Do you guys have the same issue, and is this an issue that needs attention? |
04-11-2016, 05:24 PM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
An annual brush with Waxoyl or equivalent will keep any surface rust like this at bay.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-12-2016, 04:25 AM | #3 |
175
Rep 1,596
heh, you'd be horrified to look under a 9 year old UK car :P
Heres someone selling a subframe on ebay, which is likely what you'd find under most UK cars that have done decent mileage: http://www.ebay.co.uk/itm/BMW-1-3-SE...gAAOSwGYVW89jH |
04-12-2016, 03:38 PM | #4 | |
152
Rep 645
04-12-2016, 05:18 PM | #5 |
616
Rep 3,194
But as I said in post #2, it doesn't have to be like that...
04-12-2016, 05:29 PM | #6 |
152
Rep 645
