Anyone know what this is??
04-11-2016, 01:09 PM | #1 |
96
Rep 828
Just driven home from work and was messing under the bonnet once I got home. Probably shouldn't have done it, but opened the oil cap pretty much as soon as I opened the bonnet (don't know why I did).
Got a shock when I saw this - is it because I've only done a short trip (11 miles). Car didn't even get to full temp. Scared now!!!! |
04-11-2016, 02:57 PM | #4 |
96
Rep 828
04-11-2016, 03:06 PM | #5 |
28
Rep 306
Yes could be that then, weirdly enough at the minute I'm only doing 9 miles to work and haven't seen this happening yet but I do use the motorway every couple of weeks, probably worth a little stretch down an a road or the motorway and get it upto temp every weekend to stop it
04-11-2016, 05:21 PM | #6 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
That looks like a bit more than mayo. How often are you changing your oil and filter? If you're on CBS intervals it could be indicative of sludge in the valve train...
http://blog.bavauto.com/8476/bmw-and...nge-intervals/
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-11-2016, 05:46 PM | #7 |
283
Rep 2,343
I'd change oil and filters more often.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
04-12-2016, 01:12 AM | #8 |
448
Rep 3,312
It's nothing to majorly worry about as Tin noticed the same with his 135i after only a short trip the one day. It is because the cars not getting up to temp. You need to get the car out once a week at least for a good run to get the temps up and properly get the oil moving.
E92 335i / M3 Hybrid - The Build
04-12-2016, 01:14 AM | #9 |
96
Rep 828
I've only owned it since October. It'll be getting an oil change soon though (I intend every 6k miles). It's previous owner did everything through BMW so I reckon it's probably been kept to CBS.
04-12-2016, 03:02 AM | #10 | |
96
Rep 828
Any recommendations as to which engine oil is best to go for, going forward? If I do have bits of sludge in there I want to break them down gradually, rather than have big bits break off and the car have the engine equivalent of a heart attack! |
04-12-2016, 05:10 AM | #11 |
616
Rep 3,194
If you think you do have sludge, it's probably best to consult a good indy about the possibility of an engine flush. I'm not a big fan of flushing myself, but if it's bad, it might be worth it. As for oil going forward, any good quality fully synthetic with BMW LL04 approval will be fine.
04-12-2016, 05:55 AM | #12 |
175
Rep 1,596
Make sure the thermostat is working and the engines actually reaching operating temperature.
11miles is long enough that it should be fully warmed up by then. Just reduce your oil change interval and continue using your normal oil. I change my oil every 5k. Force of habit, i like clean engines. A petrol engine should be able to do most of that 5k interval without making the oil black. If its dirty inside it will go black pretty quickly, so just change it again. After 5k the oil should still be brown. |
04-13-2016, 02:30 AM | #13 |
96
Rep 828
Gave the car a longer run on the way home from work last night, also used the paddles to try and keep the revs up. Got home, checked cap and no yellowyness - so i'm assuming that it's as RajB said and just because it was a short run.
04-19-2016, 04:48 AM | #14 |
146
Rep 2,337
Yeah give it some revs once warm. These things were built to give it some! If you've got some nice straight roads nearby take a longer route home every now and again and have a flirt with the red line!
04-20-2016, 02:19 AM | #15 | |
96
Rep 828
Have started to take your advice and give it a kickign on the way home - great fun for me, not so much for the wallet!! |
