Bought a crashed 2009 335i at auction, opinions?**UPDATED 4/13/2016 **
04-06-2016, 08:55 PM | #1 |
Rep 34
soo...
I did some disassembly today and found the crash damaged alot less than i originally anticipated. the crash beam was missed completely ,and the subframe was not cracked , bent or damaged in any way. it seems the control arms and sway bar took the most damage, the tire, wheel, knuckle, and brakes all seem in excellent condition ! the car came with intakes, BOV, downpipes, and aftermarket FMIC. which is sweet because i would have done everything but the BOV eventually anyways, the jb4 must have been removed but not the end of the world... now to the bad... the tire was pushed back into the inner fender and damaged it this is the part i need to replace... https://www.ecstuning.com/Search/Sit...68980/ES70626/ I have found lots of the parts on realoem.com and although not too expensive i have some questions for you guys on where to buy the bmw tools needed to complete this repair correctly ! i have done research and know all about the rivets, and the adhesive , but how is the old part removed ? and where is the best place to purchase these tools to do this correctly? also in the accident the windshield, as well as sunroof were broken, leading to water getting in the dashboard, and floor while it sat at the auction salvage lot the obvious at this point is that i need to dry this car out!! and my real question is, what kind of electronic damage could happen from the dash getting water? anything that would prevent the car from running? just wondering everyones take on this aspec of the repair on an e9x.... with the roof having a nice dent in it, what is the best way to repair that? i was thinking of buying something along the lines of this stud welder to pull it out . will this type of repair work for the alloy that bmws are made out of ?http://www.harborfreight.com/stud-we...kit-61433.html sorry for the long post guys here are some pics, and any advice on this repair "build" will be greatly appreciated! this is the inner fender that i will likely have to replace and am curious as to the correct way to remove the damaged section, and replace with new https://pix.sfly.com/SuX4UF https://pix.sfly.com/bRGYhG Last edited by ryanboosts914; 04-13-2016 at 12:49 PM.. |
04-06-2016, 10:07 PM | #2 |
Gateropode
329
Rep 2,848
I see many airbags deployed. That's not going to be cheap. Good luck.
Water on the dashboard could fry a lot of expensive electronic (most notably the ECU, but many other modules are under the glovebox and along the firewall, water leaks have been known to inflict severe damage in that area). Get everything dry before even trying to start the car. You'll know soon enough if you have serious electrical damage after that. |
04-06-2016, 10:19 PM | #3 |
happy.
138
Rep 464
Also it looks like they have the additional oil cooler, aka "PPK Version 2" - option code 840 or S840. Double check the vin at any BMW vin lookup site to confirm.
AFAIK that is a $1,000+ replacement alone.
'09 Jet Black E90 335i | BMS DCI | Forge DV | VRSF CP, DP, 7" FMIC, Exhaust | MHD Stg 2 / 93 Oct | Koni Yellow / H&R Sport | Mooooarrrrrr
this list is getting too long..... |
04-06-2016, 10:19 PM | #4 |
132
Rep 573
You have to buy a drill and drill out the spot welds one by one. Make sure you buy a metal bit and dont burn it out.
Then you can remove the old glue and pry the old part out. Use the new part to align the rest of the car as its aligned and undamaged. Post pics of the roof. Water damage is bad worst thing is electrical corrosion. So yeah dry and clean everything out before even connecting it to a battery. As meeni mentioned airbags are expensive. |
04-07-2016, 07:21 AM | #5 | |||
Rep 34
no airbags were deployed ! i have to take more pictures to show you but the windshield was just smashed from an exterior object, person , or animal ! as far as the water i have a dehumidifier , fans, and my garage is linked to the central air of my home. so hopefully i can get alot of the moisture out that way before starting the car(with a new oil cooler and oil obviously ) , i figure ill give it a few days and try and dry the carpets and such, im really hoping that there isnt electrical damage, if there is youll be sure to hear about it Quote:
https://www.ecstuning.com/Search/Sit...h/17227521376/ it looks like the retrofit is 1000, all i need is the cooler $325, the rest was undamaged Quote:
yikes i should probably disconnect the battery .....when i got the car from the yard, the door windows went down as i opened the doors, the trunk opened...and the interior lights go on fully....i just dont have keys ...ill go disconnect it to try and avoid any damage while its still wet. gosh i really dont wanna take that dash apart but .....if i do i guess thats the price to pay for an auction car... while im on the subject how much are the typical electrical components damaged along the firewall?? are we talking 1000s? |
04-07-2016, 08:18 AM | #6 | |
Rep 34
https://pix.sfly.com/JTXWpD |
04-07-2016, 08:33 AM | #7 |
107
Rep 485
The BMW approved method for repairing that fender support is to use their blind rivet and adhesive system. You're going to pay way more for that stuff than if you just buy a mig welder and plug weld the new support. Also, there's two pieces of sheet metal that make up that fender support. The part you posted is the largest of the two.
2006 E90 325i Sparkling Graphite Metallic
2009 E93 335i Montego Blau 2011 F10 535i Sophistograu Metallic |
04-07-2016, 08:41 AM | #8 | |
Rep 34
well just how much money are we talking for these specialty tools? i may plan on doing more bmw repair work in the future, i already have a mig welder... where can i get these tools ? |
04-07-2016, 09:13 AM | #9 | |
107
Rep 485
04-07-2016, 11:08 AM | #10 | |
57
Rep 1,038
Secondly, PPK brings an additional water cooler, not oil cooler. Water cooler goes into the driver-side fender area. Last edited by AndreyT; 04-07-2016 at 12:04 PM.. |
04-07-2016, 11:14 AM | #11 |
2832
Rep 1,784
You bought a crashed BMW? That takes some balls
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is |
04-07-2016, 12:58 PM | #13 |
93
Rep 343
04-07-2016, 01:00 PM | #14 |
douchebaggo
186
Rep 972
04-07-2016, 01:11 PM | #15 |
1706
Rep 14,829
I always looked at it like wicked hardcore lobstermen and weekend warriors (my buddy took me out on his Boston Whaler and we got screamed at for a) speeding b) getting to close to other boats' gear
pros are looking to flip salvage vehicles, so you're likely competing with them at the auction...they have the equipment to restore these vehicles, just don't have the time and won't pay more than they're worth at auction...but it's ok to do it if it's fun, kinda like playing stocks with money you can lose... |
04-07-2016, 02:10 PM | #17 |
1706
Rep 14,829
04-07-2016, 02:53 PM | #19 | |
happy.
138
Rep 464
The part I was referring to that is seen damaged is indeed the additional oil cooler (or option code S840/840) but it is not a part of the PPK package. It is, however, a requirement for getting the PPK so in that sense it does have something to do with it, just not directly part of it.
04-07-2016, 04:05 PM | #21 |
Rep 34
Well it has the parts advertised on the website for jb4 , the box was unlocked like someone quickly pulled the jb4 out before the crashed car got towed ... Really just speculation but it had to have some sort of tuning with all the parts . ..
To the central air question... Please don't flame but I cut the sheetrock in the garage and put a big metal fan right up To it pumping air from my basement into the garage , plenty of cm alarms in my home too ...not worried lol |
