TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Clock resetting after aftermarket head unit fitting
      04-04-2016, 12:43 PM   #1
Maxwell1
Maxwell1's Avatar
Drives: 330i Convertible
Hi all. Had a double din fitted in my 08 E93 Feb this year using a Connects2 kit. Stereo was fine for a month. I then had an issue with my electric roof and it went in the garage (stuck half way). Garage fixed it by resetting the main computer and the roof unit (so they say).
Since I got the car back the stereos is fine and is keeping the presets and radio stations but the car dash clock keeps resetting and a few times I have had an engine warning light come on and then disappear after restarting the car.
I've heard that I may need a new battery form other forums but I'm wondering if there is something which needs to be done to reset something?
Really annoying me as the garage and the car hifi place say the other has caused the issue! Any ideas what the issue could be and a fix?
Thanks guys.
      04-04-2016, 01:59 PM   #2
Sensible_
529
Drives: 2008 E90
Usually a sign of a failing battery. I'd get the battery properly checked. You may have a parasitic drain.
      04-05-2016, 12:26 AM   #3
Maxwell1
Maxwell1's Avatar
Thanks. Does seem that way but I just can't understand why it happened just after going in the garage.
I was off last week and did a lot more miles and it didn't go until I left it for a day or so, so it does point to battery.
What's the process for getting the battery checked? Or should I just buy a new one as I think it might be the original anyway?
      04-05-2016, 08:50 AM   #4
Maxwell1
Maxwell1's Avatar
Any other thoughts on whether I need a new battery or if there is something else needs to be looked at?
      04-05-2016, 11:04 AM   #5
John320d
John320d's Avatar
31
Drives: BMW 320d E93
Ask the garage to check the battery amperage and the alternator output.
      04-05-2016, 11:08 AM   #6
un1eash
500
Drives: M235i
Try removing and giving the battery a charge, they most likely ran it down while playing with the roof.
My car showed the same symptoms even though everyone including 2 BMW dealers saying the battery was ok. 2 weeks after a charge the clock would reset and I'd get warnings, new battery sorted it and it's been fine ever since.
      04-05-2016, 11:11 AM   #7
TBN54
427
Drives: 08' E92 335 -> 17' F30 340i
Had a similar issue with my previous E90.
Turned out it was a dying battery.
      04-05-2016, 11:33 AM   #8
Maxwell1
Maxwell1's Avatar
Thanks all. I think a new battery seems to be the consensus.
      11-17-2016, 08:46 AM   #9
Maxwell1
Maxwell1's Avatar
Hi guys. Sorry to resurrect the same issue but it's happening again!
I had my battery changed and it's been ok until this week. Now getting the same engine warning light for battery again.
Anyone else with an aftermarket head unit had this same issue?
Could it be alternator or would it have gone bad sooner than this if it was?
      11-17-2016, 10:10 AM   #10
Sensible_
529
Drives: 2008 E90
Could be alternator or could be a parasitic drain. The HU might not be shutting down properly.
How is the HU wired into the car?
I'd suggest, having the battery checked. If the battery is still good, charge it up and remove the HU. Then leave the car and monitor the voltage of the battery over a couple of days.
      11-17-2016, 11:14 AM   #11
Maxwell1
Maxwell1's Avatar
Wired using a Connects2 kit. Powered via the fuse box.
Took the car back to Car Electronics today and booked it in to have them check the alternator and maybe wire it directly to the battery rather than the fuse box. See if that works.
Battery was brand new in May so as you say, I think there is a low level drain which has gradually taken the charge down to a point where it's now too low.
You think the battery will be knackered if that is the case?
If this change doesn't work I'm ripping the lot out and going back to standard. Damn thing! All I wanted was iPhone connection but these bloody cars are a pain to add that too!!
      11-17-2016, 12:49 PM   #12
Sensible_
529
Drives: 2008 E90
In that case I would go back to standard and just add USB to the armrest with either an OEM MULF2 unit or a dension gateway or blueway 500.
If going with the gateway500 of MULF2 you can buy a cheap USB+Aux Jack Bluetooth adapter like Tune2air and there you now have streaming from your iPod to HU.
      11-19-2016, 05:46 PM   #13
Shaun69
10
Drives: 335d
Buy a multi meter and do a current draw test with the car locked, remove fuses one by one to see what's drawing current.
I've got a double din and have had no trouble at all, it could be anything draining the battery.
