JB4 with MHD Backkend Flash
04-03-2016, 03:10 PM | #1 |
36
Rep 374
Hi
Just after some advice Currently running a JB4 on Map 5 with the following mods: Catted Downpipes Exhaust FMIC Forge Bov Stett Cold Air Intake Factory Charge Pipe Have heard good things about running the jb4 with a backend flash so purchased the mhd flasher. Now I'm not sure which map i need to purchase to run with the JB4? I only run Vpower which i believe is 99 octane? Also when i tried to backup the ecu the time left kept going up to around 4000minutes remaining and was stuck on 0% !! Any advice much appreciated Last edited by jazz5000; 05-05-2016 at 04:34 PM.. |
04-04-2016, 01:52 AM | #3 |
36
Rep 374
Yes was on map5 wil give that a go
Any idea on the map? As when you press jb4 with backend flash it goes to look for a map file. On the mhd store not sure which one I need |
04-04-2016, 04:30 AM | #4 |
Rep 93
04-06-2016, 02:16 PM | #6 | |
36
Rep 374
No worries
Thanks |
05-05-2016, 04:37 PM | #9 |
36
Rep 374
Flashed the BMS Race map the other day
Car pulls alot stronger now but noticed today JB4 keeps going to Map4 after a WOT, Also it has brought up a misfire code and when i investigated it further seems i have a rocker cover leak. Is V power fuel suitable for the race map or should i switch to the pump map for the time being. Have tried to log but hard to get a 3rd gear log around here! |
05-06-2016, 02:30 AM | #12 |
67
Rep 1,431
Correct. Our 99 is about 94 USA. You will need 97+ USA for the race flash. That's about 103 UK. So a real race fuel. Very expensive.
Unless you're running meth? Then this will supplement octane. WM |
05-10-2016, 08:06 AM | #16 |
35
Rep 103
Which settings are you meant to change as I've been running a mhd pump bef and didn't alter anything?
05-10-2016, 04:24 PM | #17 |
67
Rep 1,431
