Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > What's the best way to clean the engine bay?
      04-03-2016, 10:41 AM   #1
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
My car has 226k miles on it and I'm just finishing the upgrades including an engine swap. The bay was cleaned during the install but still shows grime. It had leaky gaskets and oil grime and dirt is all over. I want to get it as shiny new looking as possible. Not doing shows but want it presentable. What's the best way to clean it? I was thinking simple green and a rag would be 80 hours of torture at this point. Would steam be a good alternative?
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
      04-03-2016, 12:12 PM   #2
Dekansnowman
Dekansnowman's Avatar
83
Drives: 2011 335i Sedan Space Grey
I've used a bunch of simple green, never sprayed directly on connections, and steam. As long as you don't get chemicals on the connections or force water in you'll be fine. Even if you do get water, remember that most engines don't have underbody trays that block road splashes and such so you'll be fine.
Spray is down, steam it off, leave hood open and let it air dry or with the help of direct sunlight.
      04-03-2016, 01:13 PM   #3
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Thx. Now I need to find a decent steamer
      04-03-2016, 01:50 PM   #4
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
6Walmart has a Wagner one for $100.
http://www.walmart.com/ip/Wagner-915...ingMethod=p13n
      04-03-2016, 02:45 PM   #5
Dekansnowman
83
Take pics when you do all this. Showing a before and after at least will help motivate people. I'll be doing the same soon as my OFHG is starting to leak, and now has made everything a mess under the hood.
      04-03-2016, 05:48 PM   #6
cpie168
173
Drives: 2010 E90 328i 6MT ZSP BSM
What are some of the sensitive areas that one should be mindful of when applying steam? What about pressure washer? Can we wrap the sensitive areas in plastic bags and then spray with pressure washer?
      04-03-2016, 06:51 PM   #7
Needbmwpartzz
Needbmwpartzz's Avatar
851
Drives: 2009 bmw 328i x-drive
Degreaser,soap water,elbow grease and a whole bunch of rags.....helps to use a spray bottle to get the liquids exactly where you want them.
      04-03-2016, 07:11 PM   #8
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
That's the 80 hours I'm hoping to avoid.
      04-03-2016, 07:21 PM   #9
Needbmwpartzz
851
Lol.....it will take 2hrs max.
I can clean my whole bay in about an hour once cowl and air filter is removed.
      04-03-2016, 07:27 PM   #10
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
The above pic was after a day of cleaning was spent with the engine and subframe removed.
      04-03-2016, 07:45 PM   #11
Needbmwpartzz
851
Yikes.....your almost there
      04-03-2016, 08:26 PM   #12
FL335
85
Drives: 2009 335i
I have read to cover up any electrical connections and spray with simple green. Hose it off with no sprayer...straight hose...not Hoes..and them wipe it clean and air dry.
I never ended up having the balls to do that but my engine is pretty clean, anyway. I touch it up from time to time.
Why are did you swap engines? I thought you had all of your modes and built it all at once? Did the motor get cashed?
      04-03-2016, 09:04 PM   #13
dauble2k5
dauble2k5's Avatar
57
Drives: 2011 VR E92 335i, 6MT
I used the Griot's Engine Detailing kit on my E46. Sprayed it on heavily, let it set a few mins, then used a brush and scrubbed at the grime. Then, took a hose with a pressure nozzle and washed it away, taking care not to get the electronic bits too wet. The whole process took maybe 30-45 mins.
Kit: http://www.griotsgarage.com/product/...tailing+kit.do
Before (about 135k miles of grime):
After:
SOLO763.00
      04-04-2016, 07:16 AM   #14
Detailed Image
Detailed Image's Avatar
360
Drives: Detailed by Detailed Image
How to Detail Your Engine Bay by Todd Cooperider
Zach McGovern
Detailed Image Ask-A-Pro Blog Author
www.AttentiontoDetailingPeoria.com
Appreciate 4
      04-17-2016, 03:20 PM   #15
Denny347
Denny347's Avatar
347
Drives: 2008 M3 E90
When I first bought this car 6 years ago, I used Simple Green, a hand rag, and a garden hose, to get it looking good. I use 404 protectant to detail the engine with. Every Spring I just wipe the engine down with a damp cloth and re apply the 404. I occasionally wipe the dust off the engine during the Spring, Summer, and Fall. I just did the first wipe down of the year today, took 20 minutes. Keep up on it and it will always look nice with minimal effort.
SOLO763.00
      04-22-2016, 12:25 AM   #16
WTF?
Giggidy..
52
Drives: 2010 335i
Mr. Moto motorcycle wash, or as its know some places.....VP racing fuel bike wash. I buy it at Cyclegear. It is hands down the best stuff I've ever seen. Dilute it, spray it on, rinse it off. It cleans like you wouldn't believe, and doesn't harm or streak anything at all.
      05-23-2016, 07:22 PM   #17
jwebb335xi
197
Drives: 2008 335 XI
I like P21S Total Auto Wash... Simple Green is pretty good too. I know this may be taboo, but i use hose, cleaner and rags. I typically put towels over the DME box, however, because I am paranoid.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs
      05-23-2016, 07:42 PM   #18
08njSTEP
08njSTEP's Avatar
795
Drives: '07 335i, '66 SS396 Chevelle
Now I'm NOT recommending this, but....
The detail guy where I work pressure washes engines every day. Never had any problems. Dude doesn't cover anything or care what he sprays. Again never had a problem of any kind.
I'm not going to do it to my car, but it seems totally safe.
