N54 oil mishap
04-02-2016, 08:55 AM | #1 |
84
Rep 971
N54 oil mishap
Hi
Just had an oil service done and they used castrol 5w30 magnatec fully synthetic instead of egde. They have offered to replace it FOC but wanted to find out if this oil will be ok before i pull the trigger. Thanks Imsy Last edited by imy; 04-02-2016 at 09:00 AM.. |
04-02-2016, 02:25 PM | #5 |
81
Rep 427
Look at Opie Oils website.
http://www.opieoils.co.uk/c-686-bmw-longlife-04.aspx It looks ok. I seem to remember, question has been raised on here before. Try a search?
F30 Estoril Blue 335D MSport.
04-02-2016, 04:28 PM | #6 |
84
Rep 971
Opieoils website has the magnatec c3 on there but castrols own website doesnt recommend it.
I did do a search couldnt find anything difinitive. Whilst the garage will replace it FOC just dont wanna put them out since they normally do a good job at serious mates rates. I usually provide my own oil but didnt on this occasion and theh just put in what Eurocarparts gave them based on my reg number. |
04-02-2016, 06:56 PM | #7 | |
283
Rep 2,343
I use Magnatec in mine. At a heavier 5w40 for better cooling of a tuned car. I'd run the oil for 6 months OP if you're worried and then change it. Unless it is LL-04 in which case you are good.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
04-03-2016, 04:53 AM | #8 |
283
Rep 2,796
In the UK BMW went for 0w-30 but when you look at the specs that can be used it's fairly wide as AWSAS has stated 5w-40 in certain cases though not endorsed say by BMW when you buy oil for the dealerships can be used, when I see the spec charts st work for oils that can be used it's more climate specific than anything else colder hotter climates highlight different 'headline spec' oils but as we are in the UK 0 or 5 w spec is fine, the use of Magnetic over Edge isn't ideal ideally it'll of been edge but Magnetic oils could have the sameish qualities say as you sticking Triple QX oil in fir Euro's but as long as it's on the LL04,spec shouldn't be a longterm drama
04-03-2016, 04:31 PM | #9 |
283
Rep 2,343
According to a chart I've seen 0w is good for down to -35C and 5w is good for -30C. The day it reaches -35C in the UK I'll consider changing my oil.
