What sub-woofers for Alpine retrofit?
03-31-2016, 02:51 PM | #1 |
115
Rep 316
Drives: 2018 F31 340i Shadowline Ed
Hi all,
I'm looking to upgrade my base idrive stereo with probably the Alpine retrofit kit as I have been offered a used one at a half decent price, I know a lot of people go for the Logic 7 under seat subs but they are pretty hard to come by and not the cheapest either for used ICE so what others would you guys recommend that are not going to break the bank? Also do other L7 subs from other BMW's fit if I put them in the E91 bracket? With regards to the Alpine retrofit kit, any pointers or anything I should be aware of? I really thought I had left the days of upgrading car stereos in my youth as back in the day I was well into it with 1000w RMS amps, JBL 12" sub woofer in a box, 6x9's, etc, etc! But the quality of stereo in my E91 is just awful and it's been over 15 years since I last installed an amp and speakers! Thanks guys! |
03-31-2016, 03:07 PM | #2 | |
66
Rep 632
The amp in the rear will provide the woofers with more power which will improve the quality. |
03-31-2016, 04:52 PM | #3 |
448
Rep 3,312
Hi Phil. The alpine kit is a direct easy install tbf. The speakers are direct replacements so there's no issues with fitting. The amp has a place in the back already and the look is ready to run straight off.
Definitely go with above and install it first and see how that sounds. You may be happy with the underseat sound until so desired to upgrade. The MB quarts are a good value replacement.
E92 335i / M3 Hybrid - The Build
03-31-2016, 06:07 PM | #4 |
45
Rep 439
Agree with your comments about the standard system being awful! The Alpine upgrade is a definite step up from the base system, not overly difficult to install either
If you're any good with coding software then many on here will recommend you code the HU to hifi as well to change the HU output to low level I've still yet to do this or hear an Alpine system that's had the HU coded but I will say that sometimes the system sounds a little sharp I'm looking to get some L7 subs too but they're seeming to be fairly rare, would be handy to see if any L7 subs from any other BMW's will fit the E92 |
03-31-2016, 06:47 PM | #5 |
23
Rep 164
My brother has the alpine kit fitted in his e92 he upgraded the underseat subs with the hifi 8" subwoofers and it sounded really good he has since sourced and fitted the logic 7 subs and honestly there is not much difference in sound between the hifi and logic 7 subwoofers
03-31-2016, 07:01 PM | #6 | |
23
Rep 164
03-31-2016, 07:07 PM | #7 | |
66
Rep 632
03-31-2016, 07:13 PM | #8 |
23
Rep 164
03-31-2016, 07:30 PM | #12 |
23
Rep 164
You need part number 65410445684 http://www.ebay.co.uk/itm/171925049082?redirect=mobile
Worth checking ebay.de can be purchased cheaper on there |
04-01-2016, 01:37 AM | #14 | ||
45
Rep 439
I'd still like it doing because I could deal with loud warning gongs if it meant I wouldn't have to adjust the bass and treble between every song |
04-01-2016, 02:32 AM | #15 |
36
Rep 278
I'm thinking of doing the same as OP. Base stereo is hopeless to say the least!
I thought after coding to hifi that the gongs are much quieter, this inlcudes the PDC beeps. Has anyone sorted these issues out after coding? Is there any way to increase the gong/pdc volumes? |
04-01-2016, 01:05 PM | #16 | |
23
Rep 164
04-01-2016, 01:07 PM | #17 |
23
Rep 164
04-01-2016, 01:17 PM | #18 |
2032
Rep 8,339
