JB4 installed and major issues..
03-31-2016, 09:41 AM | #1 |
Rep 93
Hi guys
Installed JB4 today the newest version, ran car on map 5 as I have catless downpipes and DCI. Automatic When driving my EML came on with following codes: P0087- fuel rail/system pressure- too low P0192- fuel rail pressure sensor circuit A low P0301- cylinder 1 misfire detected Reset them and off I went again, gave it some throttle and changing up gears and whilst changing it was jurking not selecting gear on autobox, then the dreaded transmission sign came on and the car seemed to be stuck in a certain gear.. Pulled over turned ignition off waited and started her back up, transmission symbol away and I can now select all the gears. Took it back up motorway then it shat itself coming up with P0301 cylinder 1 misfire and it was juddering when accelerating.. Any help or input greatly appreciated. I have since reset codes and put map to 0 all is fine. My gear oil was changed in the auto box recently car is at 73k miles.. |
03-31-2016, 09:44 AM | #2 |
10
Rep 187
In terms of the misfire, I'd check the coils.. You can swap them around to see if its faulty.. Personally I just changed all 6 coils when I had a misfire..
And change all 6 spark plugs... |
03-31-2016, 09:47 AM | #3 | |
Rep 93
Gearbox making me worried? |
03-31-2016, 09:55 AM | #4 |
427
Rep 793
First thing a lot of folks would recommend is to replace all ignition coils and spark plugs prior to doing the JB4 install.
JB4 will technically speed up the rate of the things in your car are not up to par (so to say). |
03-31-2016, 10:54 AM | #6 |
283
Rep 2,343
Before you do any of this stuff mate ensure you have up to date firmware on the JB4.
Make sure your default settings are correct and that FOL isn't set too high. Check duty bias and AFR settings. I doubt you have issues yet. I may be wrong. Maybe start off on map 1 as it's less aggressive than the auto learning map 5.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
03-31-2016, 10:59 AM | #8 |
283
Rep 2,343
Looks like it could all relate to the FOL value. Lack of fuel. Misfire.
Easy to happen on a JB4 with incorrect settings.
03-31-2016, 11:28 AM | #9 |
Rep 93
03-31-2016, 11:30 AM | #10 | |
Rep 93
03-31-2016, 02:54 PM | #11 |
Rep 93
03-31-2016, 03:17 PM | #13 |
86
Rep 1,046
Make sure you get bosch plugs. Do Not get the denso ones
Look up German Auto supply on ebay. They sell them for the lowest I've seen
2017 F80 M3 competition Sakhir Orange: // ER catless downpipes, // AA EL midpipe resonated, // MHD tune
Retired: E92 335i MSport Sapphire black: // aFe intake // Remus quad // AR Downpipe, Secondary cat delete // MHD // BMW PPK // Alpina B3 Flash // Vrsf 5" Stepped IC & CP |
03-31-2016, 04:30 PM | #14 |
448
Rep 3,312
I agree with AWSAWS in checking your JB4 settings and making sure you are definitely up to date with the software. As you say you bought it off eBay and the seller states it's only 4 months old but can't be 100% sure.
Certainly seems strange it's all ok in Map0 if their were more fundamental issues with coils etc.
E92 335i / M3 Hybrid - The Build
03-31-2016, 04:30 PM | #15 |
Rep 93
Just got Bosch coils and Bosch spark plugs from euro car parts spark plugs same as what real OEM quote, coils are the silver banded ones took a bit of a guess as they had other Bosch but black banded. Used the EASTER20 code and got all sets for £169
03-31-2016, 04:32 PM | #16 | |
Rep 93
03-31-2016, 04:35 PM | #17 | |
Rep 93
03-31-2016, 04:45 PM | #18 | |
448
Rep 3,312
Once you install it you can use the cable to check everything on your JB4 and the version numbers etc.
03-31-2016, 04:55 PM | #19 | |
Rep 93
03-31-2016, 05:38 PM | #20 |
283
Rep 2,343
Hang on, are you actually running a diesel 325D?
Do you have a JB4 or JBD? I'm thinking you've not updated your 'drives' status to a 335i?
03-31-2016, 05:48 PM | #21 |
Rep 93
04-01-2016, 07:08 AM | #22 |
Rep 93
I've had the car scanned and fault code on gearbox was 4F8A ratio monitoring, gearshift 4-5..
29CD- combustion misfire cylinder 1 (I've ordered coils and plugs for this) 2DED Power management, closed circuit current violation. This is all since fitting JB4 the gear change when in 4 to 5 with around 13psi (map1) is like it's hunting for the gear and slips. It's a slow communication with cam time line according to the technician. Is there settings for the JB4 that can be altered to rectify this or have I a dud box.. I've had my adaptions reset on autobox as it reached it limit for learning driving modes.. Again any help would be great or get tagging to who has same experiences. Thankyou |
