320i N46B20B no MAF data
03-30-2016, 05:24 PM | #1 |
26
Rep 231
hi to all. for the last year i have a very low fuel consumption. also I used to remember that I was able to read MAF values via torque pro.
now, whatever App or program i try to use (torque pro, carly, inpa, dis) i am not able to read my MAF. moreover as I said my consumptio is quite low and the car has same behaviour in what regards acceleration. never had a fault code. I tried to unplug the maf and drove for at least 15 minutes but again no fault code and no issue with engine power etc. I think that all these tend to show a problem with the dme and maf connection? maybe there is a need for a new software update? truth is i am not sure how the engine performs great with maf plugged in and totally unplugged too. maybe this is due to "saved" default fuel trims if maf goes off? what should i do? thanks.
F30 mineral grey N47 ed
04-04-2016, 12:31 PM | #4 |
26
Rep 231
hi! thanks for asking! I have used everything available on my hand!
meaning torque pro, carly, dis, inpa! also, i visited a bmw specialist garage and spoke to them and they are thinking 2 probabilities: 1. dme stopped reading maf values due to a dme failure and probably it needs a new firmware (updated) or 2. maf's failure and dme works with "default standarised" values any thoughts? i am planning to go and check it at another specialist too...
