Adjusting ambient lighting without brightening dash?
03-30-2016, 12:36 AM | #1 |
13347
Rep 7,484
They adjust with the dimmer control... and I love them but have noticed that on our F30... they are bright without the dash being bright.
Is there anyway to adjust them without the dash turning bright? Thanks |
03-30-2016, 03:24 AM | #2 |
39
Rep 133
Looked into this quite extensively when I got mine. Apparently not. No coding values to change the brightness, or none that have been found anyway. IIRC it is actually a single LED on each door that is illuminated by a clear plastic tube. You can look at increasing the voltage to the LED's or replacing them. A thread does exist somewhere showing a forum member upgrading the LED's with some kind of resistor. Thay was a bit too far for me though.
03-30-2016, 11:50 AM | #4 |
13347
Rep 7,484
Mine has a continuous stream of LEDs at closer glance... loads of tiny little ones and the light is pretty equal through the length of the LED strip..
I will leave them be if I can't do anything about them. Thanks. |
