ultimate driving machine my ass!
03-24-2016, 03:38 PM | #1 |
Rep 27
it's now been nearly a week I got my 335i and I've connected it to my computer no fault codes found drives normal a little jerky at times but it was all good. I have the common waste gate rattle which I heard doesn't cause any problems to the engine on turbo.
Last night I unleashed her fully for the first time. Floored it for around 7-8 seconds and the half bar engine management light came on, So I pulled over and switched her off for a couple minutes later switching it back on to see the engine management light was off. No error codes all clear. So with all the common problems on the 335i how can it be the ultimate driving machine if you can't really drive it to its potential? On my gti I always beat the crap out of it and not a single hiccup. For sure can't really compare the two. e92 looks much better, more class and a better exhaust note and engine noise, But none of that matters if it's constantly gonna cause problems. It hasn't even been a week and I'm already thinking to move on. Disappointed. |
03-24-2016, 03:43 PM | #2 | |
681
Rep 3,696
03-24-2016, 03:47 PM | #3 | |
Rep 27
03-24-2016, 03:49 PM | #4 | ||
33
Rep 176
03-24-2016, 03:59 PM | #6 | |
Rep 27
What does the half engine management light mean? Like it didn't stay there it went after switching the engine off and back on again. It didn't tell me the problem. as far as I know it means drive normally and get to service as soon as you can. Though I'm not sure. |
03-24-2016, 04:50 PM | #8 |
43
Rep 397
There's obviously a fault with your car mate, you need to get it to a garage or have the codes read with a proper reader.
It could be a million and one things. |
03-24-2016, 05:06 PM | #9 |
5485
Rep 5,422
Drives: Beige G31 40ix m sport
LM, the 335i is a great car, I have a 56 that I ve had for 4 years & has now done 93k. Yes things will go wrong with it, but it doesn't always mean it's gonna cost ££££ to put right. Strange that you say that it hasn't thrown a fault code, I have had the reduced power light a couple of times & it's always registered a code. First was a faulty coil. Second time it was loss of boost pressure. Does it go into reduced power under heavy acceleration?
Mrbubba, 'made of chocolate' what you talking about? |
03-24-2016, 05:10 PM | #10 |
5485
Rep 5,422
03-24-2016, 05:15 PM | #11 |
38
Rep 254
Drives: BMW M2
I've got a 57 plate 335i. Had it a couple of years now & absolutely no problems at all(as of yet).
62k miles. No wastegate rattle. In fact I was expecting something to have needed repairing/replacing by now but so far so good. Agree with the post above. Get it checked with a proper reader/diagnostics and get the problem sorted. Then maybe you can enjoy driving it |
03-24-2016, 05:29 PM | #12 | |
Rep 27
03-24-2016, 05:41 PM | #13 | |
10
Rep 187
03-24-2016, 05:47 PM | #14 |
448
Rep 3,312
I get the same on occasion but mine is pretty much FBO'd.
I'd say it's more than likely a 30FF code which can be a multitude of things. Could be a vacuum leak, actuators, etc etc. I find tbh that I get it when full throttle first time round and then reset and can go the rest of the day no problems. Don't just throw in the towel as it will be a potential minor issue and then you'll singing its praises over all else.
E92 335i / M3 Hybrid - The Build
03-24-2016, 06:01 PM | #15 |
5485
Rep 5,422
LM, no worries. I would still suggest you find a local Indy & get the fault memory read rather than just check it on your computer. My local guy charged me £45 the first time I took it to him. Once you have a code & an idea of what's wrong you could take it back to the dealer with knowledge of the fault in case they try bullshitting you. If the dealers any good they will get it sorted.
As for making it go faster I run 386bhp & 460 toques & that cost me £825. 108mph 1/4 mile. Don't be disheartened you have bought a 335i & it will make you smile. |
03-24-2016, 06:03 PM | #16 |
53
Rep 1,249
Problem could be that its a 9 year old car that may or may have not been ragged its hole life, the bmw service book only really includes oil and filter changes, brake fluid and pads etc, dont mention anything about spark plugs coils etc, so it could well be something pretty simple that bmw may well have not picked up on, theres not many cars out there unless an enthusiast has owned that would have had every service item and maintenance item done.
A car will only last so long before these bits need doing anyway, and if your thinking of tuning it you need to start with a good base by making sure you have a 100% correct running car before adding another 100 bhp to it
E90 lci 330d, alpine white, pro nav, adaptive xenons, heated electric leather, folding mirrors, alpine retrofit kit with L7 subs, performance grilles, 40w led angel eye bulbs
03-24-2016, 09:03 PM | #17 |
283
Rep 2,343
You have a lot to learn OP
Your problem is most likely minor. A bad spark plug or coil that needs replacing probably. Maybe crappy fuel. Were you running 95 or Premium? You have to use premium for a boosted car like this. This is just the cars way of protecting itself from damage. Better this than to have something go bang. Get yourself a way to read faults\codes. Replace bits as necessary. These cars are absolutely solid with massive, massive potential to be unleashed. In my opinion fuel pump and wastegate issues are over exaggerated. Good luck! You'll have a blast.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
03-24-2016, 09:24 PM | #18 |
19
Rep 128
Cant stand posts like this with new owners not doing their research or maintenance properly. Seems minor issues like AWSAWS mentioned make people hate on the N54.
93K on my '07 drives great, just have to maintain it properly like everyone says. My previous '08 had 103K and drove just fine. |
03-25-2016, 05:31 AM | #19 |
96
Rep 828
Agree with the above. It could be anything. I had the same issue. Mine turned out to be a collapsed vac line. Was replaced FOC by A1BN.
03-25-2016, 08:12 AM | #20 |
15
Rep 59
I can sympathise with the OP. Might have been a tad OTT but I'm kinda with him on questioning BMW being the "ultimate driving machine".
I've been driving for a long time and have owned a lot of different cars, but never have I come across or owned a brand that has as many "common faults" as BMW does. Especially for the 2000s model years. It's such a glitchy car across a lot of models.... Dodgy fuel pumps, abs pumps, coil packs, nox sensors, roll over sensors, injectors.. rattling waste gates, noisy wheel back plates, cracked alloys, seizing alternator pulleys... and the list goes on. All common faults. I'll probably get team defensive blah blah blahing now, but without bmw tinted glasses on.... these cars are pound for pound the most unreliable motors I've ever seen, and the most expensive to fix mainly due to ridiculously expensive parts. To be fair, the majority of the problems don't seem to be engine related, meaning you don't break down and get left stranded.... they mostly appear to be everything else that is bolted on. Not sure if that's a good thing though. Would I recommend a mate buying an E9X... I don't think I could without feeling a bit guilty. |
03-25-2016, 08:26 AM | #21 | |
851
Rep 2,793
Bmw profits from all these little parts that break.....now tell me do you think they will fix those problems? I think not! |
03-25-2016, 11:08 AM | #22 |
167
Rep 1,415
Tags |
335i, auto, engine light, gti, service |
