Performance Exhaust Fitting
03-16-2016, 08:53 AM | #1 |
36
Rep 336
Hi
I am hoping to get the PE exhaust soon, found it cheaper to get it through the cotswold group on here and hopefully have it fitted at an indi garage. My local BMW dealer wanted around £830 fitted. My question is would most indi garages be fine with fitting it given that i believe the original pipe needs cutting for the PE to be clamped on. Basically is it a pretty straight forward fit if I find a decent local exhaust garage. Many thanks |
03-16-2016, 09:19 AM | #2 | |
130
Rep 1,534
Went to an exhaust specialist who took half and hour to fit it. |
03-16-2016, 10:40 AM | #4 |
36
Rep 336
Thanks richk85, what model was it you had? Doesn't surprise me. I'd be saving the best part of £250 by taking to a decent exhaust specialist to be fitted.
03-16-2016, 10:53 AM | #5 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
If it's not included in the box, ask your supplying dealer for a printout of the comprehensive BMW fitting instructions, which will help your exhaust specialist know where to cut.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
03-16-2016, 11:14 AM | #6 |
130
Rep 1,534
03-16-2016, 11:32 AM | #7 |
448
Rep 3,312
Shouldn't be an issue for most exhaust places tbd. A lot of factory exhaust are single piece and need to be cut to fit a replacement backbox etc. The place next to Darren Wood is worth a go as I know they've done custom work too.
E92 335i / M3 Hybrid - The Build
03-16-2016, 01:06 PM | #9 | |
36
Rep 336
