F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Brake shudder - warped discs are a myth!
ARMA SPEED
      03-15-2016, 02:13 AM   #1
harkes
harkes's Avatar
China
1077
Drives: M135i, E39 M5, NSX and AE86
Hi
Has anyone succesfully removed brake shudder by sanding their brake discs?
The reason I ask is, that according to Brembo, there is no such thing as warped discs! However, brake pad material can be transferred unevenly which will give the same result.
Edit: It is Stoptech that claims the above http://www.stoptech.com/technical-su...d-other-myths#
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      03-15-2016, 02:55 AM   #2
SDH
409
Drives: .
Originally Posted by harkes View Post
Hi
False! I've had two sets replaced in the last year due to being warped. Admittedly it wasn't the discs at fault (they didn't warp of there own accord) but they were warped nonetheless.
Sanding? do you mean skimming/machining a few thou off?
      03-15-2016, 03:03 AM   #3
harkes
harkes's Avatar
China
1077
Nope - I mean sanding, with garnet paper apparently:
http://www.clublexus.com/forums/ls-4...e-problem.html
Google: garnet paper brake rotor
Ill give this a try in the weekend
(A Dane in China)
      03-15-2016, 08:06 AM   #4
Polo08816
1610
Drives: 2014 335i M Sport
Do you track your car extensively?
      03-15-2016, 08:33 AM   #5
SDH
409
Drives: .
No turns out the front wheel hubs were damaged which screwed up 2 sets of discs.
Edit: don't worry this wasn't on an F30
      04-04-2016, 10:18 PM   #6
sly1types
432
Drives: F80M3 and E46M3
They are correct it's always uneven pad deposits. As soon as you feel it you need to bed them in. If not you can always get it out but you might have to use a more aggressive pad.
My dad ended up getting 100k+ on his original brakes by doing this...granted he drives normal.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104
E46 M3
F85 X5M
https://www.instagram.com/fastmacm3/
f30post
