BMW X5 and X6 Forum 2014-Current
Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > Vendors Classifieds
      03-11-2016, 01:32 PM   #1
AutoTalent
AutoTalent's Avatar
2307
Drives: e92 M3 6mt | e60 M5 6mt
AutoTalent: KW Suspension Distributor | KWV3 Coilovers available for F85 X5M | F86 X6
AutoTalent | KW Suspension | KW V3 for BMW F85 X5 M | F86 X6 M
General Features:
Dampening technology with individually adjustable rebound- and compression technology
inox-line* stainless steel technology
Individually height adjustable
Adjustment parameters approved by the German Technical Control Board (TÜV)
High-quality components for long durability
Infinitely variable rebound Dampening adjustment
14-way adjustable compression Dampening
Unique, individually working Dampening force adjustment
Comprehensive documentation for easy use
Specific Features:
with adjustable compression and rebound Dampening
TÜV approved
Front lowering adjustment ranges (min.-max.): 15-45 mm (0.6-1.8 inches)
Rear lowering adjustment ranges (min-max): 15-45 mm (0.6-1.8 inches)
Front Spring Rate: 25-55mm (1.0-2.2 Inches)
Rear lowering adjustment ranges (min-max): 15-45mm (0.6-1.8 Inches)
Front Spring Rate: Progressive
Rear Spring Rate: Air
Part #352200AM (With EDC)
Part #352200AL (Without EDC)
Unlimited individuality for performance & comfort. Suspension systems separately for the rebound and compression damping.
As with any KW coilover develop our suspension engineers for the vehicle-specific applications of the KW coilover suspension Variant 3 "inox-line" a sporty-harmonic base vote. In addition to tests on our KW 7-post vehicle dynamics test bench we complete this extensive test drives on highways, the highway and even Nordschleife at the Nürburgring test kilometers on test kilometers, to guarantee the finely tuned suspension. For years, the world's top aftermarket products counting KW coilover suspension Variant 3 "inox-line" is the reference for coilovers. With its damping characteristics, high quality finish and excellent durability, it convinces demanding sports car driver, tuner, wholesale and small manufacturers as Alpina, MTM, Manthey, Oettinger and many other well-known companies in the international automotive industry.
Cutting edge technology from motor racing
much more than a sporting Lowering and an excellent performance on all roads, choose the KW coilover suspension variant 3 "inox-line". It is based on our long experience as a chassis manufacturer and supplier in international motorsport, such as in the touring car series ADAC GT Masters, FIA GT1, FIA GT3, International GT Open, WTC, VLN and the legendary ADAC Zurich 24h Race Nürburgring.
Similar to our racing coilovers from KW Competition program can "inox-line" the rebound and compression damping can be adjusted independently at the KW coilover variant. 3 This individual adjustment possibility is valued by refiners, racing car manufacturers, tuners and demanding drivers around the world.
The perfect suspension setup for significantly improved driving dynamics
you have already performed first performance modifications to your sporting road vehicle, it is easy with the KW coilover suspension Variant 3, these targeted in the to consider damper settings. The patented KW-valve technology for the separate vote of rebound and compression damping allows you customize the vehicle-specific basic set of KW. For example, you are the adjustable in twelve clicks in low-speed range of the pressure stage KW-bottom valve the latitude to take into account even the tire characteristics of your high and ultra-high-performance road tires in the suspension settings.
The patented compression adjustment at the lower piston end of the stainless steel housing needed you do not even have tool. The adjustable compression coordination with its twelve exact clicks allows you manually to Karosserieroll- and roll to influence, without having to change the optimal matching spring rate rebound.
With the individually adjustable Zugstufenabstimmung the KW coilover suspension Variant 3 "inox-line" can They directly affect the handling and control by the precise click adjustment. Depending on the type of vehicle Zugstufenventile the KW twin-tube dampers are tuned at the upper end of the piston rod with an integrated adjuster or the included in delivery Plug-adjuster.
By increasing the tension, the body movements of the body are reduced through the adjuster. Your car drives by trail loyal and you have at elevated cornering speeds even more stability. For example, change of the shared wheel / tire combinations of your car manufacturer to larger wheels, you can vote Variant 3 "inox-line" the handling of your car and your new alloy wheels perfectly with the KW coilover suspension.
High-quality, personalized and durable
During production is the KW coilover variant subjected 3 "inox-line" extensive quality tests and checks each individual damper. Only in this way we achieve our aspiration to ensure the installation of a KW coilover suspension Variant 3 "inox-line" by KW retailer for a period of up to five years. By filigree processing and the use of high quality components, the KW coilovers stainless steel to 100 percent, for example, stainless and have an unlimited service life.
As a result, the operation of the continuously variable lowering via the dirt-resistant KW trapezoid thread and the KW polyamide threaded ring is not affected by age. Through individual lowering with their infinitely variable range can be the sportiness of your vehicle visually emphasize. A feature that is very popular in the performance oriented tuning scene. - In rebound and compression damping Independently adjustable damping technology - stainless steel technology inox-line - individual, stepless lowering - TUV-tested lowering - quality components for long life - adjustable rebound damping with 16 exact clicks - 12-way adjustable compression damping with click adjustment - unique, independently functioning damping power adjustment
How to Place Your Order:
Phone Domestic: (310) 231-0292
Phone International: (310) 231-0292
E-mail: Golan@AutoTalent.com
Website: www.AutoTalent.com
Payment:
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
      03-22-2016, 09:24 PM   #2
AutoTalent
AutoTalent's Avatar
2307
Bump!
      03-29-2016, 12:53 PM   #3
AutoTalent
AutoTalent's Avatar
2307
Bump!
      04-04-2016, 01:51 PM   #4
AutoTalent
AutoTalent's Avatar
2307
Bump!
      04-12-2016, 02:24 PM   #5
AutoTalent
AutoTalent's Avatar
2307
Bump!
      04-25-2016, 06:33 PM   #6
AutoTalent
AutoTalent's Avatar
2307
Bump!
      05-03-2016, 06:36 PM   #7
AutoTalent
AutoTalent's Avatar
2307
Bump!
      05-09-2016, 12:47 PM   #8
AutoTalent
AutoTalent's Avatar
2307
Bump!
      05-31-2016, 06:01 PM   #9
AutoTalent
AutoTalent's Avatar
2307
Bump!
      06-07-2016, 05:38 PM   #10
AutoTalent
AutoTalent's Avatar
2307
Bump!
      06-28-2016, 04:16 PM   #11
AutoTalent
AutoTalent's Avatar
2307
Bump!
      07-13-2016, 02:13 PM   #12
AutoTalent
AutoTalent's Avatar
2307
Bump!
      07-18-2016, 04:01 PM   #13
AutoTalent
AutoTalent's Avatar
2307
Bump!
      07-25-2016, 05:10 PM   #14
AutoTalent
AutoTalent's Avatar
2307
Bump!
      08-04-2016, 12:57 PM   #15
AutoTalent
AutoTalent's Avatar
2307
Bump!
      08-22-2016, 07:06 PM   #16
AutoTalent
AutoTalent's Avatar
2307
Bump!
      09-14-2016, 08:35 PM   #17
AutoTalent
AutoTalent's Avatar
2307
Bump!
      10-03-2016, 04:27 PM   #18
AutoTalent
AutoTalent's Avatar
2307
Bump!
      10-20-2016, 04:44 PM   #19
AutoTalent
AutoTalent's Avatar
2307
Bump!
      11-01-2016, 03:50 PM   #20
AutoTalent
AutoTalent's Avatar
2307
Bump!
      11-29-2016, 02:16 PM   #21
AutoTalent
AutoTalent's Avatar
2307
Bump!
      12-13-2016, 03:28 PM   #22
AutoTalent
AutoTalent's Avatar
2307
Bump!
