Steering wheel vibration
03-08-2016, 03:09 AM | #1 |
96
Rep 828
So as per my thread, I've got a nice vibration coming through the steering wheel between 45 and 55mph (both on acceleration, deceleration and braking) that I could do with your help in diagnosing.
+wheels have been re-balanced (one now has 60g of weights on!) + tyres checked... no feathering Next things I was going to check are the control arms and the steering rack bolts (I get a nice clunk when turning the wheels whilst stationery every so often). Re the control arms... I was thinking of upgrading the arms to M3 arms. Question is, do I have to replace both the upper and lower arms, or can i just replace the lower control arms? |
03-08-2016, 08:39 AM | #3 |
96
Rep 828
03-08-2016, 09:01 AM | #4 | |
283
Rep 2,796
Vibrations can be a sod to get your head round and usually you have to go through certain things one by one to get to the route cause, tyres are an ideal starting point as you have to ask yourself pre post wheel change were the issues your now experiencing present, if the wheels are 1/2" wider using the same tyres as in their current condition effected how things are now panning out but all you can do is go through the basics and hopefully you'll find the answer to this annoying issue Last edited by old grey steve; 03-08-2016 at 09:08 AM.. |
03-08-2016, 09:22 AM | #5 | |
96
Rep 828
03-08-2016, 09:25 AM | #6 | |
283
Rep 2,796
03-08-2016, 09:44 AM | #7 | |
96
Rep 828
03-08-2016, 12:44 PM | #8 |
96
Rep 828
Ok so steering rack bolts tightened up. There was room to tighten but not much.
Jesus it's scary working that far under a car - even with ramps and Jack stands!! |
03-09-2016, 01:41 AM | #9 | |
448
Rep 3,312
Apart from the normal tyres/balancing etc then sometimes it's bushes/balljoints so the M3 arms are a definitive good move.
E92 335i / M3 Hybrid - The Build
03-09-2016, 02:23 AM | #10 | |
96
Rep 828
....Just need to do a GEO after the arms... this thing is a money pit, hahah! |
03-09-2016, 02:34 AM | #11 | |
448
Rep 3,312
Although mostly due to our own doing
03-14-2016, 05:08 AM | #12 |
96
Rep 828
Right this vibrating is driving me nuts now. Sooner these M3 arms show up, the better.
I'm learning that the car needs a GEO after they've been replaced. I've had a look on the M3 side of the fence for wheel alignment specs but they're quite confusing... 0degs 10' of total toe at the rear?!? Does anyone have a set of specs that I can give to my tame mechanic? His machine is ancient but spot on in terms of calibration, so there's no database on it to take a set of specs from. |
