2011 E9x/E82 Diagnostic & Programming - ISTA or INPA/DIS?
03-06-2016, 03:32 PM | #1 |
96
Rep 406
Drives: S54/N52
Hello all,
My apologies for such a novice question..... but.. I've been looking online for a definite answer to this question... For 2011 E9x / E82 chassis' can I use INPA/DIS/SSSv41 for program/reset steering angle sensors, adaptation and what not? or do I definitely need ISTA D/P for the purpose? I see that INPA/DIS only supports upto MY2008 (Correct me if I am wrong?) but somehow, I see some people are successfully performing diagnostics, reset adaptations, program in new modules after replacement, etc... using INPA/DIS/SSS And I see posts where people say you cannot do any of that for newer model year cars, unless you have ISTA setup. Please be merciful with flaming! Thank you very much in advance!! |
03-06-2016, 05:53 PM | #2 | |
555
Rep 1,244
Drives: 2013 F10 M5
You can "technically" hack up SSS to support newer vehicles, but that's a massive gamble. If you want the proper tools for diagnostics, you can use a K+DCAN cable and ISTA/D rather easily. Programming is another game, you can program basic modules like the DME, etc. But anything on the MOST (fibre optic bus) like the navigation system, etc. you really want an ICOM A+B along with ISTA/P and a good stable power supply, otherwise you risk seriously screwing up your car by bricking ECUs. |
03-06-2016, 07:40 PM | #3 |
96
Rep 406
Drives: S54/N52
Thank you for the clear-cut answer!
I will definitely pick up a K+Can cable and will dig further into ISTA |
03-17-2016, 10:21 PM | #4 |
Rep 27
Guys i need help with DIS ver57, i am able to use it on my 2006 330xi, but today i try to run diag on my 2008 x5, i can connect but bot able to run diag to pull error codes, it connects and goes through to where it is suppose to pull vehicle info automatically, but it says no data can be pulled obd error or so.
I did test it on my friends 2008 328I and does same thing. But it works fine on 2006 330xi. Please suggest. Thank you |
03-18-2016, 11:49 PM | #7 |
1915
Rep 13,107
I used these websites.
http://softwarezload.blogspot.com/20...-download.html
http://cartechnology.co.uk/showthread.php?tid=10224 Also be aware that you need get daten files that are uptodate with the current software levels on your car for them to work correctly for Inpa Ncsexpert or ista d /p There are also some links right on this board. |
