M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2 MPE Valve Controller Question
      02-28-2016, 04:47 PM   #1
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Do you think it will be possible to configure the M2 MPE valve controller like the link below on the M3/M4 MPE using the garage opener buttons?
http://f80.bimmerpost.com/forums/sho....php?t=1229519
      02-28-2016, 05:36 PM   #2
Kantalias
146
Drives: 2016 M2
Probably a good question for CG Precision. I'd be interested in hearing what they have to say if you get any info.
      02-28-2016, 06:13 PM   #3
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Email sent to CG Precision.
      02-28-2016, 06:42 PM   #4
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Very quick reply from CG Precision:
Yes, our controller will absolutely work on the new M2, both with the stock and M-Performance exhaust.
Good job CG Precision
Appreciate 4
      02-28-2016, 07:41 PM   #5
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
Nice!
Current
AW BMW M2
Past
VO BMW 1M
      02-29-2016, 09:23 AM   #6
Kantalias
146
Drives: 2016 M2
Cool!
      04-12-2016, 10:27 PM   #7
CG Precision
CG Precision's Avatar
94
Drives: 2013 BMW 335i
Thanks! With the M2 part numbers now available, we can see that you need a VSC-1 controller, for the single valve, rather than the VSC-2 you linked to in your original post which is for the dual valves of the M3/M4. Functionality is identical between both products. We are exited to hear some more M2's!
      04-13-2017, 09:19 PM   #8
fryh1n
fryh1n's Avatar
Drives: 2007 Z4M Coupe
2020 BMW X3MC  [0.00]
2008 BMW Z4MC  [0.00]
Does this control module remembers the last setting used?
Does the valve stay open when the car is turned off, so when I start it up again, it's at open position?
Oh, and does it come with instruction on how to program the Homelink buttons on the rearview mirror?
Thanks!
      02-19-2018, 09:37 PM   #9
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Revive this thread anyone has used CG precision valve controller? It’s a little confusing what CG people said above, because M2 on MPE is a dual valve system.
      02-20-2018, 04:44 AM   #10
DroneandDone
94
Drives: 18 MG M2
I have it but I honestly don't think it's ever worked. I originally had it set to stock/default and open/turned on. that didn't seem to do anything. then the shop said that it was because I should have put on the open/default and closed/button pressed. So we changed it to that unit. I honestly can't tell the difference. I still have it on but I'm not sure it's done anything. probably a waste of money. I have a 2018 MT with stock exhaust.
m2
