2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions 2016 M235i unable to connect in ESys
      02-25-2016, 07:20 PM   #1
clyjr
Drives: 2016 M235i
I have a brand spanking new 2016 M235i, downloaded ESys,launcher,Psdzdata, watched several videos and guides but I'm getting the following error when I try to connect :
Open connection failed. [C028]
selectProgrammingTarget for Ethernet failed with MCDError
(53315) internal error - (28) could not parse Db project
[1692]
I've already made sure the launcher is set for F022 series, and in the connection dialog I'm choosing "..VehicleInfo=F020" and connection via VIN (My vin does show up).
I get the above error after attempting to connect.
Any ideas?
      02-25-2016, 07:25 PM   #2
clyjr
Drives: 2016 M235i
More info, I'm using the following :
E-Sys v.3.27.1
E-Sys Launcher Premium 2.5.3
v.58.0_PsdZData_Lite
Laptop is a fresh install of Windows 10, Windows Firewall is turned off completely.
      02-25-2016, 07:55 PM   #3
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
E-Sys v.3.27.1
probably your psdzdata was installed or unzipped incorrectly
      02-26-2016, 11:35 AM   #4
clyjr
Drives: 2016 M235i
Your thinking was correct, I got version 57.3 of PSDZDATA and I can happily say I have successfully connected and made my first coding change.
      02-26-2016, 11:40 AM   #5
pikcachu
pikcachu's Avatar
1399
      03-02-2016, 02:24 AM   #6
pyroboy024
Drives: 2016 ///M235i
Do you have a link to the 57.3 of PSDZDATA. I just installed all the Esys software today and I am waiting on my ENET cable to arrive. I am currently running the same versions as you and also have a 2016 M235. Any help in advise is appreciated
      03-04-2016, 01:11 PM   #7
clyjr
Drives: 2016 M235i
Just noticed your post, you are going to want to go here http://www.bimmerfest.com/forums/sho...d.php?t=638188
to get the latest software. I'm not sure if it's ok to pass download links but if you ask in that thread you will probably get a PM in a surprisingly short amount of time...
      03-05-2016, 02:55 AM   #8
pyroboy024
I was able to code mine with v58
2addicts
