My wife wanted to do something nice for me and now I got this to solve :(
02-25-2016, 04:13 AM | #1 |
Rep 75
My wife decided to vacuum my car and clean the interior. I was so happy and I felt loved She used interior cleaner on the screen and now I got this. right away love turned into
It's like it ate the coating on the screen!!! Do I have to replace the screen or is there a layer in front of the screen? Anybody with similar problem? |
02-25-2016, 04:44 AM | #2 |
19
Rep 150
Other than replacing - there may be a way to remove upper film, order new film and apply it. But I've never seen actual diy, just talk. Not so uncommon your problem. I sort of did that on one car, but wasn't that severe though, never bothered since lease was up.
02-25-2016, 12:41 PM | #3 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
:conf used2:s lap:
02-25-2016, 02:55 PM | #4 |
456
Rep 2,749
this is well known problem
there is no film on this screen, this is special coating you can remove rests of the coating and then cover plastic with film or you can reinstall screen to pre-lci idrive monitor box, it has additional plastic glass in front of the screen you can buy new screen because 80% of the used CIC screeens will have same scratches
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
02-25-2016, 06:13 PM | #6 | |
31
Rep 234
02-25-2016, 06:36 PM | #7 |
541
Rep 3,131
Drives: 2011 335i e92 DCT
Is there a chemical that can be rubbed on to remove all of the film so at least its even?
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
02-26-2016, 03:29 AM | #9 | |
Rep 75
https://en.wikipedia.org/wiki/Narrow_range_ethoxylate https://en.wikipedia.org/wiki/Isothiazolinone narrow-range ethoxylates (NRE) killed the coating i think. Or alcohol could do it also!? Other component is conservative but not a chemist I just continued using this fine product, and almost all of it is gone now but in sunlight its terrible. I ordered anti reflex "screen protector" for ipad and Ill cut/try applying it on the screen. I must take the screen out to make it look nice I think.... The coating is really fragile.... |
02-26-2016, 03:33 AM | #10 | |
Rep 75
02-26-2016, 03:37 PM | #11 |
51
Rep 308
Drives: 2007 328i
I wonder if you got anti glare glass for a picture frame and put it in front of it. Idk if they make it in a lexan... glass should be fine there.
