02-12-2016, 02:15 PM | #1 |
24
Rep 293
Brake upgrade
I've got a 335d f31.
When pushing the car, I've found the brakes give up after while. Pads need doing in about 4K miles so I'll upgrade them then, more than likely ebc yellow as on my e92. Has anyone upgraded there brake fluid and hoses? Did it fix the issue? Many thanks |
02-12-2016, 04:10 PM | #3 |
General
8571
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
I've changed to braided hoses and the fluid to a dot5.1.
Don't notice much difference on the road, but at Bedford it meant I was able to 4-5 laps with no drop off in braking performance, whereas earlier in the year I struggled to get through 3 laps without the pedal going long. It's more than enough for the public road I would have thought in terms of heat management and endurance. I'm actually fitting ebc pads on Monday along with the ACS RS suspension, so can tell you then if there is any discernible improvement.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
02-12-2016, 04:25 PM | #4 |
3105
Rep 7,032
Drives: 335xd Msport +
Anybody tried the m performance discs with the dimpled look simillar to cross drilled.
Do they improve braking or just cosmetic ?
02-12-2016, 04:27 PM | #5 |
6431
Rep 8,503
I replaced the stock brake lines with HEL braided lines around 3 months ago and there's a noticeable improvement - more linear relationship between pedal pressure and brake bite, especially when hauling the car down from speed.
The sponginess has all but gone, even running OEM pads with M-Sport calipers. The standard pads aren't the best; EBC Yellow Stuff may improve things further.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
02-12-2016, 04:30 PM | #6 | |
6431
Rep 8,503
02-12-2016, 04:36 PM | #7 | |
General
8571
Rep 19,982
God, there isn't much left on my car that hasn't been modified...
