Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (G11) 7-series General Discussions
      02-08-2016, 09:15 AM   #1
Jason
Administrator
Jason's Avatar
40786
Drives: F80 M3
Arrow Introducing the all new 2017 Alpina B7
BIMMERPOST NEWS
68
COMMENTS
Name:  Screen Shot 2016-02-08 at 7.41.49 AM.jpg
Power, Dynamics and Luxury combined for class-leading performance and a superior driving experience – the all-new 2017 BMW ALPINA B7 xDrive.
  •  Unique combination of high-performance drivetrain with 600 bHP and xDrive all- wheel drive system provide a 0-60 mph acceleration time of just 3.6 seconds.
    • 4.4L 8 Cylinder twin-turbo charged engine
    • 600 bHP from 5750-6250 RPM
    • 590 lb-ft from 3000 RPM
    • 3.6 0-60 is 0.8 seconds faster than predecessor
    • ALPINA sport exhaust reduces back pressure and weight
    • ALPINA Switch-Tronic 8 speed automatic transmission
    • No torque reduction is necessary during upshifts
  •  Most advanced suspension and chassis technology with ALPINA calibration including for the first time Integral Active Steering for ultimate dynamics and comfort.
    • 2-axle air suspension
    • Active Roll Stabilization
    • Rear wheel steering (part of Integral Active Steering)
    • 1.6 inches of ride height adjustment available
  •  Carbon Core body in conjunction with ALPINA specific suspension geometry and MICHELIN® Pilot Super Sport tires lead to high agility, direct handling and precise steering.
    • 21" forged wheels saves 5.5 lbs per wheel
  •  Special ALPINA Sport+ Mode adjusts all vehicle, drivetrain and suspension settings to maximum dynamic performance lowering ride height by 0.8 inches at the touch of a button.
  •  The ALPINA design and aerodynamic elements underscore the elegant and athletic appearance of the new BMW ALPINA B7 xDrive.
Woodcliff Lake, N.J. February 8, 2016... Today, BMW of North America announced the all-new 2017 BMW ALPINA B7 xDrive, the third generation of ALPINA automobiles based on the BMW 7 Series offered in the US. The all-new BMW ALPINA B7 xDrive stands for luxury paired with precision dynamics, effortless performance and comfort at the highest level. The 2017 BMW ALPINA B7 will be available in September 2016 at selected dealerships. Price will be announced closer to market launch.
New generation 4.4 liter V8 engine with twin-turbo charging.
The new 4.4 liter 8-cylinder engine with twin-turbo charging, gasoline direct injection and Valvetronic delivers an impressive output of 600 bHP between 5750 rpm and 6250 rpm, while the maximum torque of 590 lb-ft is available from 3000 rpm. The resulting performance figures are remarkable – the all-new BMW ALPINA B7 xDrive accelerates in just 3.6 seconds from 0 to 60 mph, 0.8 seconds faster than its predecessor while reaching a top speed of up to 193 mph (preliminary figure).The power output of this smooth high-tech engine unfolds with impressive emphasis across the entire rpm range. Excellent throttle response and high torque ensure that even at low engine speeds driver inputs are immediately transformed into forward acceleration.
In addition, to ALPINA’s engineering expertise, a number of significant technical details are responsible for this engine’s power output and performance characteristics – particularly the air intake system, the intercooler and turbocharger configuration and the high-performance cooling system. The twin-turbo charging system comprises two specially developed turbochargers positioned in the V of the 8-cylinder engine. These feature twin-scroll turbochargers with enlarged inlet and outlet diameters. This configuration ensures optimal use of exhaust gas energy even at low engine speeds. The result is a fast power build-up and more torque at low engine speeds for overall exceptional engine response. At 2000 rpm the ALPINA’s V8 twin-turbo engine already produces 494 lb-ft of torque ensuring optimal performance.
The overall aim during the development of the components of the ALPINA air intake system - from the air intake ducts to air filter housings and clean air intake manifold - was to achieve maximum airflow. All components of the high-performance cooling system are designed to remove bottlenecks and maximize effectiveness – special large-volume coolers are interconnected by large diameter hosing for maximum throughput. An indirect intercooler system (air to water) facilitates the implementation of short charge-air intake paths. Combined with additional external water coolers and a transmission oil cooler, the system ensures the thermodynamic stability of the V8 twin-turbo engine at all times, even under the highest loads and ambient air temperatures.
Inside the engine special Mahle pistons and NGK spark plugs are designed to deal with the temperatures and loads associated with 20 psi of boost pressure and a compression ratio of 10.0:1.
The stainless steel ALPINA sports exhaust system is responsible for a reduction in back pressure and weight. Active exhaust valves allow the driver to influence the sound experience by switching the Driving Dynamic Control switch between Comfort and Sport Mode. In typical ALPINA fashion: the two twin tailpipes of the exhaust system are integrated elegantly and aesthetically into the rear apron.
Name:  Screen Shot 2016-02-08 at 7.51.04 AM.jpg
Most advanced suspension and chassis technology with characteristic ALPINA dynamics.
The all-new BMW ALPINA B7 xDrive features cutting-edge suspension technology, offering its driver an exceptional range of driving experiences. The focus to retain the exceptional long-distance cruising comfort of the predecessor while at the same time significantly sharpening the agility, handling and lateral dynamics commensurate to the power output of the all-new BMW ALPINA B7 xDrive.
The 2-axle air suspension system combined with Dynamic Damper Control and Active Comfort Drive with Road Preview guarantees the very highest level of driving comfort at all times while the Active Roll Stabilization minimizes body roll during cornering. The rear wheel steering of the Integral Active Steering system gives the all-new BMW ALPINA B7 xDrive a level of dynamic performance and light-footed handling, typically associated with sports cars. The Driving Dynamics Control switch serves as the central control over which to select the various parameters of all the systems that influence the driving dynamics of the all-new BMW ALPINA B7 xDrive. It also features an Individual Mode, which can be used to combine specific settings independently and in accordance to the driver’s preference.
With the Driving Dynamics Control used to select the appropriate mode, the 2-axle air suspension system is primarily responsible for the exceptional level of ride comfort. It also enables ride height to be changed up or down which in combination with the other suspension systems facilitates the choice of a decidedly comfort or sport orientated chassis set-up. Overall, a maximum ride height adjustment range of 1.6 inches is available. At speeds above 140 mph the ride height of the BMW ALPINA B7 xDrive is lowered by 0.8 inches. This operating state, which can be activated manually to be effective regardless of the speed by selecting the special ALPINA Sport+ Mode, results in a lower center of gravity thereby increasing agility and high-speed stability. The lower ride height results in increased front wheel camber for even more direct turn-in when cornering. When needed, the ride height can also be raised by 0.8 inches up to a speed of 20 mph in order to increase ground clearance.
The settings of the Electronic Damper Control, which influences both rebound and compression, are also selected using the Driving Dynamics Control. A broad range of ALPINA damper set-ups are available ranging from Comfort+ Mode for effortless and relaxed cruising to ALPINA Sport+ Mode for maximum dynamic performance.
For the first time, the all-new BMW ALPINA B7 xDrive features Integral Active Steering, which in conjunction with the high-performance drivetrain and the all-wheel drive system, offers a dynamic driving experience par excellence. The Integral Active Steering combines a variable ratio electric steering system at the front axle with active steering on the rear axle whereby the wheels can turn a maximum of 3 degrees. Specially attuned to the ALPINA suspension and MICHELIN® performance tires, the rear axle steers opposed to the front axle at low speeds for increased agility and dynamic handling, while steering with the front axle at higher speeds for maximum high-speed directional stability.
The all-new BMW ALPINA B7 xDrive is fitted with MICHELIN® Pilot Super Sport tires measuring 255/40 ZR20 at the front and 295/35 ZR20 at the rear, mounted on 8.5 x 20 and 10 x 20 ALPINA CLASSIC wheels. New lightweight 21 inch forged wheels take the traditional 20-spoke ALPINA CLASSIC design into a new minimalistic and technical direction. Forging results in high-density and high-strength aluminum alloy which enables a weight-optimized construction that saves 5.5 lb of unsprung mass per wheel. The MICHELIN® Pilot Super Sport tires are specifically designed to meet the demands of high- performance sports cars. They contribute directly to the precise steering feel and handling of the new BMW ALPINA B7 xDrive while foregoing run-flat technology in the interests of improved ride comfort.
Comprising blue painted 4-piston fixed calipers and 15.5 in x 1.41 in discs on the front axle and floating calipers with 14.5 x 0.94 in discs on the rear axle, the high-performance brake system provides outstanding stopping power and deceleration.
Name:  Screen Shot 2016-02-08 at 7.51.53 AM.jpg
BMW xDrive intelligent all-wheel-drive system with ALPINA calibration
The all-wheel drive system builds upon the technical potential of BMW’s xDrive system and its intelligent and dynamic distribution of drive power which continuously and fully variable distributes torque between the front and rear axle within milliseconds for maximum traction and control. The programming of the torque distribution control, which is interconnected with the Dynamic Stability Control and the engine management system, is performance-oriented and it increases driving agility and dynamics markedly – especially under lateral acceleration – while maintaining balanced and neutral handling. Besides allowing optimum traction under acceleration by eliminating slip induced losses, the system continuously monitors a wide range of sensory inputs – for example steering angle, lateral acceleration, yaw angle and speed – to distribute torque so as to achieve maximum safety in challenging conditions or when encountering sudden changes in road surface friction. The DTC Mode of the Dynamic Stability Control offers a more rear wheel drive bias torque distribution for even more dynamic handling.
Automatic 8-speed Sports Automatic with ALPINA SWITCH-TRONIC.
The BMW ALPINA B7 xDrive utilizes a new generation of the excellent 8-Speed Sport Automatic Transmission with ALPINA SWITCH-TRONIC. Further refined and adapted to the performance characteristics of the high-torque V8 twin-turbo in collaboration with ZF, the transmission offers exceptional driving comfort in all situations.Close gear ratios and a total spread of 7.81:1 improve shift comfort and efficiency. In Automatic Mode the combination of eight gears and high engine torque makes for relaxed, luxurious cruising at low engine rpm even when travelling at higher speeds.
In Sport Mode the shift points have been optimized for improved driving performance and are considerably more dynamic with the option to activate the Launch Control function. For maximum dynamic performance, the driver selects the Manual Mode thereby actuating gear changes manually by using the SWITCH-TRONIC buttons on the back of the steering wheel or via the gear selector switch on the center console. In addition to lightning quick gear shifts (approximately a tenth of a second), this mode also holds the selected gear even when the engine hits the rev limiter.
All components of the transmission such as the torque converter with lock-up clutch, the planetary wheel sets and the inner cooling are designed to specifically cope with the high torque output of the V8 twin-turbo engine. This means that no torque reduction is necessary during upshifts when selecting the Launch Control or when using the sportiest configuration of the Manual Mode. This contributes significantly to the striking longitudinal dynamics of the all-new BMW ALPINA B7 xDrive and allowing it to sprint from 0 – 60 mph in just 3.6 seconds. The transmission features the latest Comfort and Efficient Dynamics functions such as ConnectedShift (use of navigation data for an anticipatory shift strategy based on traffic routing) and Coasting (decoupling of the engine and transmission when coasting).
Athletic and elegant design throughout the B7.
The appearance of the all-new BMW ALPINA B7 xDrive is defined by athletic flair and elegance. The ALPINA design and aerodynamic elements emphasize its performance character, with the front and rear spoiler striking a harmonious balance and highlighting the powerful presence of the 2017 BMW ALPINA B7 xDrive. The design blends form and function – the aerodynamic components reduce lift on the front and rear axles to almost zero for maximum driving stability at all speeds. Openings at the front of the vehicle allow the precise and effective flow of air to the individual components of the high-performance cooling system. The iconic BMW kidney grille is fitted with an integrated air flap control system that adapts to the BMW ALPINA B7 xDrive’s cooling needs: when closed it further reduces the level of aerodynamic drag.
The 20 inch ALPINA CLASSIC wheels with twenty spokes and concealed air valves give the powerful BMW ALPINA B7 xDrive a touch of elegance and lightness. In the interests of weight reduction and a striking technical appearance, the optional 21 inch ALPINA CLASSIC forged wheels with visible wheel bolts do not feature concealed air valves and wheel caps.
The ALPINA sports exhaust system features two elliptical twin tailpipes that reflect the performance of the all-new BMW ALPINA B7 xDrive and its powerful V8 engine. They are precisely integrated in the rear apron and give the rear a smooth, elegant look.
The exclusive paint finishes in ALPINA Blue metallic and ALPINA Green metallic are a hallmark feature reserved solely for BMW ALPINA automobiles. Other BMW and BMW Individual paint finishes are also available for the 2017 BMW ALPINA B7 xDrive.
Name:  Screen Shot 2016-02-08 at 7.52.49 AM.jpg
Interior and Equipment.
An extensive range of standard equipment ensures maximum well-being and comfort, including high-end Nappa leather, comfort seats, a leather-covered instrument panel, ceramic inserts on selected control elements and soft close doors. Equipment features that enhance effortless driving also come as standard in the new BMW ALPINA B7 xDrive, such as a full-color Head-Up Display, a rear view camera, the latest BMW navigation and communication and infotainment systems.
ALPINA details add exclusivity and individual style to the interior. Hand-finished using exceptionally high-quality LAVALINA leather, the sports steering wheel with blue and green stitching is captivating at the very first touch due to its gentle feel. Timeless Piano lacquer or classic Myrtle Luxury Wood - the ALPINA interior trim, door sills with blue illumination, ALPINA B7 model inscriptions and an individual production plaque are further examples of exclusive equipment features in the new BMW ALPINA B7 xDrive.
Another exclusive ALPINA design is the full-color digital instrument panel in LED technology. In Comfort Mode it offers a classic look featuring round instruments with blue background and red needles. In Sport Mode the display changes to a more dynamic design with blue and green drag indicators and a focus on primary information, such as the centrally positioned permanent digital speed read-out.
OFFICIAL VIDEO
2017 BMW Alpina B7
Appreciate 6
      02-08-2016, 11:02 AM   #2
constantin
constantin's Avatar
Madagascar
44
Drives: 4wheels
Wow. Fantastic numbers.
      02-08-2016, 11:05 AM   #3
Vallyshy
Vallyshy's Avatar
23
Drives: Stock 05' E46 M3
How much is this bad boy going for, 115K?
      02-08-2016, 11:13 AM   #4
YungDro
1089
Drives: -
thread closed....
      02-08-2016, 11:15 AM   #5
e92ben
e92ben's Avatar
1053
Drives: BMW M3 BMW 635csi
What a beast!!
e92 ///M3
      02-08-2016, 11:15 AM   #6
YungDro
1089
Drives: -
thread closed....
      02-08-2016, 11:16 AM   #7
Anchored
64
Drives: E39
140k Starting I bet!
I bet that digital dash can be coded
      02-08-2016, 11:18 AM   #8
Rams_M340
Rams_M340's Avatar
39
Drives: 2020 BMW M340i
2020 BMW M340i  [0.00]
Amazing, so beastly
      02-08-2016, 11:19 AM   #9
Danconia
Danconia's Avatar
70
Drives: G11
Video is wtf.
2017 Alpina B7 Cialis Package.
2019 X7
2016 G11
2009 E60 M5
2008 E90 M3 - Gone
Appreciate 7
      02-08-2016, 11:22 AM   #10
TheBingoBalls
TheBingoBalls's Avatar
3820
Drives: BMW
Best looking version of the G11 7er. Love Alpina's simplistic design.
Appreciate 2
      02-08-2016, 11:25 AM   #11
Db750
278
Drives: 2014 991S & 2013 M3 CP
This gen 7 looks really good in that Alpina blue color. Beautiful car with amazing performance!
2014 911 Carrera S - White/Two Tone Espresso/Cognac - Aerokit Cup...
2013 F12 M6 - AW/Black Merino - Loaded
2018 F150 XLT Sport - Lightning Blue/Black Cloth - 5.0 V8 4D/4WD...
      02-08-2016, 11:28 AM   #12
goj
goj's Avatar
2253
Drives: 2016 EBII 340i 6-MT
I would replace the wheels with some that don't cover the lug bolts. Aside from that I'm really loving the lighter blue (but not too light) on a car like the 7.
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
      02-08-2016, 11:28 AM   #13
RingMeister01
Croatian
RingMeister01's Avatar
No_Country
884
Drives: PORSCHE
Bless Alpina
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only)
Husqvarna FS450 (track only)
Looking for an SUV
      02-08-2016, 11:28 AM   #14
jcoop269
55
Drives: 2010 e82 n52
Beautiful car.
That video is retarded but probably an accurate depiction of the customer base.
      02-08-2016, 11:31 AM   #15
E92LNGCGY
434
Drives: F97/Q5/982 GT4
What a monster. Usual Alpina upgrades as expected. This would cost a small fortune.
      02-08-2016, 11:32 AM   #16
MSport28
MSport28's Avatar
79
Drives: F80 M3 / G30 540
Wow. I've never wanted a 7-series until this minute! (big car, don't need the room and wouldn't want to "sacrifice" performance) She is a beauty and a beast! Love it!
      02-08-2016, 11:35 AM   #17
jzmundy
jzmundy's Avatar
991
Drives: F97
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S
Appreciate 2
      02-08-2016, 11:44 AM   #18
ando
ando's Avatar
2001
Drives: i5 eDr40, G80 and F80
2024 BMW i5 eDr40  [10.00]
2022 BMW M3  [7.50]
2015 BMW M3  [0.00]
Impressive.
      02-08-2016, 11:53 AM   #19
Doctor///M
Doctor///M's Avatar
1792
Drives: 2023 AUDI RS6
2023 Audi RS6 Avant  [0.00]
BMW M2 Competition   [10.00]
2009 BMW 335i  [0.00]
2015 M3  [9.52]
What's the secret keyhole behind the steering wheel? All I could find in the very long description is something to do with the "Driving Dynamics Control switch." Maybe I missed something.
2020 F87 M2 Competition /l\ LBB /i\ Executive Package
2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV
BMW CCA Member
      02-08-2016, 11:57 AM   #20
vladberca
vladberca's Avatar
Romania
763
Drives: '18 octavia 2.0 tdi dsg
I am curious about the weight compared to the previous model!
      02-08-2016, 12:06 PM   #21
Sean@PSI
Sean@PSI's Avatar
2133
Drives: 2021 IOMG M3 Sedan
ALPINA FTW as always!
      02-08-2016, 12:07 PM   #22
3M TAPE
3M TAPE's Avatar
No_Country
350
Drives: M3
Man, I would take this over the F10 M5 in any day if the price wasn't an issue
7post
