Shudder from the Driveline
02-04-2016, 10:21 PM | #1 |
671
Rep 1,442
Was cruising along at 80 mph and punched it. Water meth kicked in and I got a strange and disturbing shudder from the driveline. My gut tells me it is not the tranny. Got new tires recently from a crappy but cheap tire shop. I decided to get my tires road force balanced and they were slightly out of balance... not huge, but out of balance. I think it might be the driveline... specifically the drive shaft but I am reluctant to retest for fear of blowing up my driveline/transmission.
Road force balancing was a good move no matter what... car now drives like it is on glass. Any ideas would be appreciated. |
02-04-2016, 10:39 PM | #2 | |
106
Rep 292
Drives: 2011 335d
Garage List 2017 Audi Q7 [0.00]
2011 BMW 335d [0.00] 2006 Nissan Titan SE [0.00] 2008 MB CLS550 [0.00] 2012 BMW X5 SAV [0.00] |
Just a thought. BTW, still enjoying the Ohlins?? |
02-04-2016, 11:08 PM | #3 | ||
671
Rep 1,442
Ohlins are still fantastic! For those of you who enjoy firearms, it is the Sig Sauer P226 of suspension components. |
02-05-2016, 10:15 AM | #4 |
213
Rep 2,210
02-05-2016, 10:46 AM | #6 |
765
Rep 3,558
There is a part on the front end of driveshaft you may want to inspect. Yozh has mentioned this before possibly causing driveline vibration. He had a nickname for it ... something like a grubber?
02-05-2016, 10:55 AM | #7 |
765
Rep 3,558
This is what Yozh was talking about. item #1. Hopefully problem is just running out of meth/water mix and your u-joint is fine.
http://www.realoem.com/bmw/enUS/show...diagId=26_0233 |
02-05-2016, 11:26 AM | #8 | |
671
Rep 1,442
02-05-2016, 11:27 AM | #9 |
73
Rep 462
I have been having the same problem intermittently. I do not have water meth, so it cant be that in my case. It doesn't do it all the time, but sometimes when I lay on it, I get a shudder.
#1 looks like a cush drive of some sort. Hopefully that is the problem. I have read that the gasser guys have issues with the carrier bearing going bad and sometimes causing vibration. |
02-05-2016, 11:30 AM | #10 |
671
Rep 1,442
If the Ohlins were cheaper they would be the Glock 17 of coilovers.
02-05-2016, 11:44 AM | #11 |
213
Rep 2,210
02-05-2016, 11:54 AM | #12 |
106
Rep 292
Drives: 2011 335d
02-05-2016, 02:30 PM | #13 |
240
Rep 1,288
With our insane torque, I am surprised we haven't seen guibo's being destroyed much sooner. I've killed a couple in my past, one on my former e36M3/4, one on an e28 535, and one on my e30M3.
02-06-2016, 07:13 AM | #14 | |
614
Rep 2,410
When I was first dialing things in I'd get a shuddering if I had too much fluid going in at low/medium rpm range and it was a quench issue.
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
02-06-2016, 09:59 AM | #15 | |
106
Rep 292
Drives: 2011 335d
02-06-2016, 10:07 PM | #16 |
Rudolf/German/Compression Ignition Specialist.
53
Rep 168
Experienced this shudder last week under w.o.t. however it made the car go into limp home mode... figured it was more electronic related than mechanical. Anyone else hit limp mode when they experienced this?
02-07-2016, 01:22 AM | #17 | ||
671
Rep 1,442
02-07-2016, 07:41 AM | #19 | |
614
Rep 2,410
It would be a simple test where you can modify your controller settings to adjust the injection strategy to see if it's quench or not. Manually shift the car into 4th gear at rpm's at ~1600 rpm and roll on the skinny pedal and see what happens at the low/medium rpm range where boost will likely be the maximum level (assuming you have stock turbos and IWG). I think you'll be surprised how easy it is to induce quench at those lower rpm's... If you get quench, try adjusting the onset of injection and/or decreasing the maximum injection amount and repeat and see if you can cause the shudder to stop. This kind of test should be able to isolate if it's quench in very short order.
02-07-2016, 10:42 PM | #20 | |
427
Rep 1,040
You can definitely experience quench at over 14 psi if it comes in too fast.... |
03-07-2016, 11:23 PM | #21 | |
671
Rep 1,442
I have also noticed in the past three weeks that a lot of the guibos are now failing based on the posts of late. |
03-08-2016, 11:19 AM | #22 |
103
Rep 580
I'm gonna +3 on the quench idea. It took me quite awhile to get my 2-stage dialed in correctly with 50-50. Like TDI said, the twins are pretty much lagless, so boost comes up almost instantaneously. My 2nd stage starts at 20psi.
